Results 1 to 4 of 4
Thread: Dual Fuel Electronic Ignition - timing retard
    Advanced LandRoverGhost's Avatar
    Jun 2016
    Warrumbungle
    Exclamation Dual Fuel Electronic Ignition - timing retard
    From my old dual fuel Range Rover I had salvaged a modern A&R Dual Fuel Electronic Ignition.
    But my 'new' 1989 GQ was already fitted with a Piranha Ignition System. ....
    Would it be possible to mate the two?
    First contacted the maker of the Dual Fuel Ign. in the U.K. - (V8Engines) as friendly as but no conclusive answer.
    Then contacted Piranha Australia - same story as friendly as but also no real help.
    Eventually bit the bullet and started.
    The Piranha appears to be a timing ignition only , not an amplifier. So I could use the output of the Piranha - which normally went to the coil - and connect that to the A&R input where normally the signal from the Lucas Range Rover or points distributor went.
    Bingo !! Back in Dual Timing Business.
    The A&R unit allows for a generous difference between LPG and Petrol timing.
    In brief it works like this:
    We tune for optimum LPG timing with the distributor.
    Then switch to Petrol and see the timing retarded - this can be fine-tuned on the A&R unit with a small electronic settings screw.
    That's all.
    Here is a link to the A&R unit :
    http://www.v8engines.com/faq-a-and-r.htm
    Good Luck !
  2. The Following 2 Users Say Thank You to LandRoverGhost For This Useful Post:
    dom14 (15th September 2016), taslucas (10th November 2016)
    Advanced AGman's Avatar
    Mar 2016
    I don't see why it wouldn't work, getting specifics on wiring it up to the Patrol might be your only issue. They are pretty vague about this on their website but I would give it a crack if it was me.
    Nov 2016
    A bit ambitious, how'd you go?
    Jun 2016
    Warrumbungle
    Hi , currently camping so limited computer abuse :-) It went really well, both the old Range Rover timing-retard unit and the Piranha are working flawless together. Also modified the gas carburettor part from Impco to a Blos plus plus OVML dual stage evaporator plus full custom K&N air filter setup. Will describe in detail once home as it works magical. The whole operation turned the car into a real good performing machine. More like what one expects from a 4.2 petrol at top-tuning.
