The radio facia section just pulls out. Its clipped in. The lower part where the ciggie lighter is, you need to remove the centre console first, then there is two screws at the base of this part to remove.
There are 2 screws near the heater pos/fan speed knobs remove them
I use a plastic moulding removal tool to prevent scratching it.
Take your time the radio will stay put
They will all be similar i reckon but what series are you mate? Series 1 to 3 will be the same then series 4 through to current will be slightly different but the same rules as above apply.
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
On another note be real careful if you do have a woodgrain one as they seem to be more brittle than the standard black ones.
If you crack a woodgrain one you cant order them direct through nissan anymore either. Cracked mine when removing it.
