Results 1 to 6 of 6
Thread: GU center removal
    May 2016
    8 Post(s)
    GU center removal
    Hi all need to get the centre dash incert out so as I can look at the heater controls . how is it fitted thanks Tip12345
    The master farter
    mudski's Avatar
    461 Post(s)
    The radio facia section just pulls out. Its clipped in. The lower part where the ciggie lighter is, you need to remove the centre console first, then there is two screws at the base of this part to remove.
  4. The Following User Says Thank You to mudski For This Useful Post:
    Tip12345 (30th August 2016)
  5. #3
    There are 2 screws near the heater pos/fan speed knobs remove them
    I use a plastic moulding removal tool to prevent scratching it.
    Take your time the radio will stay put
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #4
    330 Post(s)
    They will all be similar i reckon but what series are you mate? Series 1 to 3 will be the same then series 4 through to current will be slightly different but the same rules as above apply.
  8. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  9. #5
    May 2016
    8 Post(s)
    woo thanks all That is a nice wood grain panel. Must keep an eye out mine has a standard radio with no instructions !! dont even think it is stereo!
  10. #6
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    On another note be real careful if you do have a woodgrain one as they seem to be more brittle than the standard black ones.
    If you crack a woodgrain one you cant order them direct through nissan anymore either. Cracked mine when removing it.
    2002 GUIII Ti 4.8
    Details here
