Results 1 to 2 of 2
Thread: PATROL Y61 TB45E (ABS) (4 INCH LIFT) 1997-2001 -SAFEBRAKE Performance Hoses
    Dec 2014
    Give your Patrol Y61 GU TB45E a real brake bite for more enjoyable driving!
    Easier to lock all 4 wheels during steep off-road
    tactical tracking for 4WD vehicles.
    Our Key Advantages:
    • Unrivalled flex-life (18 million normal cycles) for exceptional durability.
    • Minimal volumetric expansion (hose swelling) due to 3.4mm Heavy-Wall designed which results in powerful braking and amazing feel.
    • Negligible water ingress, meaning brake fluid is not contaminated and performance is not compromised.
    • Long service life while maintaining the same high level of braking performance.
    • Safer motoring - Improved braking performance over standard rubber brake hose.
    • Unrivalled braking performance for track and racing application, regardless of the size of brake rotors and calipers.
    Product Code:
    NP-Y61.4.5-AB.4IN
    Nissan Patrol Y61 4.5L (ABS) 1997-2001
    Applicable model: Suits Y61 4.5L (ABS) with 4 Inch Suspension Lift.
    Compatible calipers:
    Standard Patrol Y61 4.5L front & rear calipers.
    Compatible fluids:
    DOT 3, DOT-4, DOT 5 (Silicone), DOT 5.1 (Glycol Ether/Borate Ester)
    Includes in the packaging are:
    Front left axle = 1 hose
    Front right axle = 1 hose
    Front Centre LH = 1 hose (100mm longer)
    Front Centre RH = 1 hose (100mm longer)
    Rear LH axle = 1 hose
    Rear RH axle = 1 hose
    Rear Centre = 1 hose (120mm longer)
    (Suits GU TB45E with 4 Inch Lift)
    Total: 7 hoses kit
    + following documents:
    - Warranty Card
    - Suggestion for Safety
    - Limited Warranty (Terms & Condition)
    - Installation Suggestion
    Installation Note:
    This SAFEBRAKE brake hoses kit fit like standard part, without modification required.
    5 Years Warranty
    Our Quality Commitment: When you purchase SAFEBRAKE® brake hoses, you get peace of mind knowing that you are entitled to five years warranty. Even though we are confident that our product will last the lifetime of your car, we offer an active 5 years warranty so we able to monitor your satisfaction in using our product. The warranty will give you full replacement of the product should there are defects due to manufacturing. (Please refer to our Warranty Terms & Conditions)
    This is our commitment to ensure the reliability of our products and quality acknowledgement. Thank you for your kind support.
    SAFEBRAKE
    Available for all Nissan Patrol models and more.
    PM me for price & delivery.
    Feb 2017
    Hi safebrakes can you send me a price on a 1993 gq TB42e patrol running 4-5 inch lift Teflon braded lines 6 total I think. Cheers
  4. The Following User Says Thank You to Lucas Bree For This Useful Post:
    PeeBee (3rd October 2017)
