Results 1 to 10 of 18
Thread: GU 4.2ti aircon compressor bearing
    Aug 2016
    Gday folks, just wandering if anyone has a guide for changing the clutch bearing on a td42ti gu aircon compressor.
    I've read a few threads about it but the links to the info I'm after seem to be outdated. Thanks for any help
    Steve
    Are you just chasing the idler bearing or the compressor bearing mate?
    Aug 2016
    Yeah the actual compressor bearing. Idler has been done.
    Cheers,
    Steve
    Aug 2016
    Also to clarify, the compressor noise only goes when the aircon is switched on. It's got the rumble of a worn bearing. Is replacing the compressor bearing likely to fix this or does it mean a new compressor?
    cheers,
    Steve
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    The clutch bearing spins all the time, is the noise there all the time? Mine will make a noise when you start the car with the ac on then it goes away.
    462 Post(s)
    Quote Originally Posted by cairns gu View Post
    Cheers,
    Steve
    Its common for the 3ltr a/c compressors to chew out the idler brg in the pulley. Same would go for the TD compressor to I would assume. So with no belt on the pulley, how does the pulley spin? Nice and free, or does it sound and feel a bit rough?
    Aug 2016
    Sorry yeah the pulley has been done, it's fine. Just when the compressor engages the noise starts then starts and stops as the compressor switches on and off
    462 Post(s)
    Yeah ok. Sounds like the compressor itself is shot. Could be a bearing, or even the vanes inside the compressor.??
  10. #9
    Aug 2016
    Yeah after having a bit of a look it probably is the compressor. It isn't real bad, just noticeable and the aircon is still cold so I'll just use it til it breaks. At least it's got it's own belt (not serpentine, shouldn't affect anything else if it seizes?)
  11. #10
    yeah if it seizes just cut the belt off. I have seen a very comprehensive writeup on the internal bearing replacement. it needed to be pressed out and was an impressive writeup. Note sure what forum it was on though to be honest?
