24th August 2016, 01:31 PM
Running Power into the Rear
Hi.
I need to run some power cable into the rear of my 2013 Y61 for a few fridges. Is there an easy/good place to get access from the underside of vehicle and into that rear cargo area???
Thanks.
24th August 2016 01:31 PM
24th August 2016, 03:24 PM
There is a large rubber bung under the right rear to poke wires through.
There may well be one on the left as well
Or ,,,,you could run wires along the kick panelsfrom the front to rear
using a snake to access the cargo area.
24th August 2016, 04:05 PM
threedogs
Yep that's a good idea.
When I ran wire for my lightbar I couldn't believe there was a complete blanking panel I could remove, drill out and put back. I love these vehicles.
The Following User Says Thank You to 10G For This Useful Post:
threedogs (24th August 2016)
24th August 2016, 09:32 PM
I recently had to run power to the back of the vehicle for power distribution, but at the same time I needed to run a 50 amp feed for the trailer and 20 amp feed for the trailer brakes. Given that a lot of this had to go out the back I ran power under the vehicle and then I ran the fridge power into the bung at the bottom of the panel. It was a bit of a pain but was otherwise OK. If I only had to run power for the fridge I would take off the kick panels and run it inside. Also, maybe you should consider running a second power cable in case you want to put camping lights out the back in the future?
WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
25th August 2016, 10:04 AM
Thanks for the help. I'm trying to get things ready for a trip in 3 weeks and am running out of time.
