20th August 2016, 08:38 AM
Air tanks?
I need a new project and I was thinking about installing my spare ARB compressor with an air tank in the rear somewhere to be used for airing up tyres. I know a number of you have already done this so I'm after some advise .....
Is it worth it, is it an advantage, or am I better off sticking with my Thumper when needed? If the answer is yes, what size air tank do you recommend to make it viable, bearing it mind the available spaces inside or under my y61?
Thanks guys
20th August 2016 08:38 AM
20th August 2016, 12:12 PM
I am he, fear me
Got one in my Ute, about 20 litre or so up under the Tray.
Great addition IMHO, quicker to air up, you can run kickarrse air horns, add a small reg and you can run Air Tools.
Hard to squeeze that big a tank in a Wagon of course but you could maybe run two small tanks to give you decent reservoir capacity
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
bazzaboy (20th August 2016), MB (20th August 2016)
20th August 2016, 01:00 PM
You could fit a 4 gallon tank on your cargo barrier, I have tank and pump in one bolted there,
you can also bolts a tank up along the sills, Best thing ever great for air tools as ET stated,
good for blowing out air filters out bush too.
20th August 2016, 01:28 PM
Travelling Podologist
I have a 9 litre tank fitted with the Boss PX07 compressor. Handy when using an air gun, but probably not big enough for a lot of air tools except for short bursts. A mate has used the same compressor to inflate 20” tyres on his OKA for years without a tank. Not sure I’d bother with a tank if starting again. FWIW the Boss tanks (several different sizes) are excellent quality & relatively lightweight being alloy, also means no long term issues with rusting from inside.
The Following User Says Thank You to Cuppa For This Useful Post:
20th August 2016, 01:54 PM
http://www.ebay.com.au/itm/New-Air-C...IAAOSwAvJW9csz
This will run my front locker and air horn,
15yrs ago I had a set up like Cuppa's same tank and pump
The tanks come in a variety of sizes from 3ltr hotdog ones
that fit along the sills to larger, or you could just use a portable tank
pre filled,
http://www.ebay.com.au/itm/5-GALLON-...8AAOxyeR9THqIV
bazzaboy (21st August 2016)
20th August 2016, 11:06 PM
Top idea Bazza, works well for me too.
Roughly 20L ute chassis mounted tank to 150psi off an ARB twin.
Great for quick tyre inflate blasts 0< >40psi (30-60 secs 'guesstimate' on a 33" 60+ on 35")
By the time you've moved to next tyre, tank is back to 150psi blast ready again.
20th August 2016, 11:21 PM
I am he, fear me
... forgot to mention that an air tank means it is easy peasy to reseat a bead as well
bazzaboy (21st August 2016), MB (21st August 2016)
20th August 2016, 11:22 PM
#8
21st August 2016, 01:07 AM
#9
21st August 2016, 08:03 AM
#10
MB
Thanks for the numbers MB, good to know. I also agree with you on the location of the tank. I think if I'm to go ahead with this, for my peace of mind, the tank needs to be able to fit under the truck. If this is possible I may be able to go for a much larger capacity tank. This would would open up more options for it's use and make the effort & expensive justifiable.
Thanks MB. ( Thanks all )
