Results 1 to 4 of 4
Thread: GQ Custom Center Dash board
    May 2016
    Cairns
    hi all,
    am almost ready to start working on my 1995 GQ to get her both running and livable as a family wagon. as such a few bad ideas have popped into my head for projects, the most recient of which is making a custom dash center. The main reason for this started because I would like to put in an android double din for a reversing camera and really don't like the idea of putting it right down the bottom where the radio currently goes. So after starring at the problem for a while I thought to myself, what if i put the heater controls down the bottom and made a double din just below the air vents. At that point the bad ideas started namely the idea started to run away on me so instead of double din what about the biggest screen i can jam in there (8-10.2" are the current likely suspects) making a whole new fascia out of 40-50 thou aluminum which would allow me to simply screw monstrosities straight onto the new fascia provided i bent it up and had then securely fastened to other structure else where.
    any how before i fork out the cash and invest myself prematurely in a project that cant be done I have a question for you all, has any one played around with relocating the HAVAC controls? is there lots of spare cable for dropping it down as much as 30cm or alternatively what are the options for making after market cables that are longer?
    thanks in advance
    -Spannerdriver
    Beginner Dads GQ's Avatar
    Sep 2018
    Quote Originally Posted by Spannerdriver View Post
    hi all,
    thanks in advance
    -Spannerdriver
    I know this is a couple years old but I am thinking of doing the same thing!!
    How did you go with it??
    Oct 2011
    Central Victoria
    Quote Originally Posted by Dads GQ View Post
    Seen a few guys mount on on top of the center of the dash, you could get one looking pretty good by cutting the bottom of a spare dash center and sticking it on top of the current dashboard
  5. The Following User Says Thank You to neet_wagon For This Useful Post:
    Dads GQ (15th October 2018)
    Newborough, VIC
    134 Post(s)
    I have seen on Facebook before, a picture of a dash that a bloke had done exactly that. He made it from fibreglass and it looked like it came from the Nissan factory.
  7. The Following User Says Thank You to Winnie For This Useful Post:
