13th August 2016, 07:49 PM
Glow plug rocket cover oil seals
Hi I think my glow plug oil seals need replacing. Is hard job or pretty easy ☺️
13th August 2016 07:49 PM
13th August 2016, 10:21 PM
Glow plug seals are easy. Just remove the intercooler, then the glow plug rail, unscrew the seals and replace.
The injector seals however requires you to remove the injector lines and then use a screw driver and lever out the old seals then replace.
Just remember to bleed the fuel system properly or you will damage the injector pump.
14th August 2016, 04:24 PM
14th August 2016, 10:02 PM
Hi all went well but I found a lot of black mud in air intake is hard to get the intake off ( fuel line ) to clean it 😳
