12th November 2014, 02:18 AM
GU ZD30 Fuel pump
Hello everyone, hope someone can help me out here...
I have a Patrol 2003MY ZD30DDTI engine with a no starting problem, there is no fuel pressure reaching the injectors and the fault "P0073 P3-PUMP COMM LINE" is stored in the engine module, after doing a little research it seems to be a blown transistor in the high pressure fuel pump, I checked and there is continuity between the module and the pump. Is there a way to confirm is not a faulty ECU? Anyways I need to remove this pump in order the check it out and discard it...
So I need the correct procedure to remove this pump (Nissan #16700VG100), has anyone else experienced this problem in the past?
Many thanks!!!
12th November 2014 02:18 AM
13th September 2016, 04:34 PM
Hey mate how did you go with this I've got a Navara with a zd30 had 0076 spill valve 0073 pump comm line also a crank position sensor fault turns out it had a broken solder in the injector pump controller after changing injector pump I still have the 0073 pump comm line fault and no injection everything is bleed up. just wondering what yours end up being cheers
