Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Looking for some help with a few questions
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Today I fitted my catch can to my 2013 Y61 ZD30, and while I was under the bonnet I thought I'd take some photos and ask a few questions.
    When I was fitting the catch can, this thing got in the way, it's the ting with 37K on it. What is it?
    Click on any picture to get a bigger picture...
    There's a hose coming out of that thing and going into another thing above in that pic, this thing:
    What's that & what does it do???
    While I had that plastic cover off the top of the motor, I noticed all this oil oozing around this hose:
    I'm guessing that's from NOT having a catch can????
    I hope it's from not having a catch can, otherwise I reckon I've got something to worry about.
    Thanks for any help.
    I would say you have a leaky Intercooler, and yes all that oil is from not having a catch can.
    You can remove the IC and clean it then pressure test it.
    Those spare plug ends you'll find heaps all over the place they are for different spec models
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Ok photo one is a vac canister.
    It's basically a resivour but for vacume pressure for things like the brake and clutch boosters..
    The later models don't have them fitted anymore..
    The solinode looking thing I'm not 100% sure of. Do you have a factory rear diff lock?
    And the oil leak.. where there is oil there is boost leaks. Tighten the hose clamps..
    Yes the catch can will greatly reduce the amount of oil going threw the system..
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    G'day threedogs. Thanks for helping out. Is removing the intercooler an easy job??? And how do I get it pressure tested??
    Thanks again.
  6. #5
    W.A. (wandering aust)
    Thanks again.
    I/C removal takes maybe 20 minutes the first time you do it then maybe 5 minutes once you have it sorted
    Your intercooler isn't leaking all that much from the pics.
    Intercooler leaks will have that brown/black crud but will be where the Intercooler Core attachs to the Tanks.
    Check these out https://www.google.com.au/search?q=z...w=1240&bih=878
    That leak on the pipes just needs tighter/better clamps.
    The VNT will be very forgiving for boost leaks anyway.
    All that happens with small leaks is the ECU will control the Turbo vanes to keep increasing pitch until the ECU boost demand is met.
    That happens in like 10ths of a second
    It takes quite substantial leak to max out the Turbo Vanes so that you can't get max boost
  7. #6
    Once cleaned you can tape up one end and using a bike pump introduce some pressure
    to the IC via the other end thats taped as well, submerge in some water, make sure its dry
    before reinstalling.
    Use any type of solvent to clean but make sure its dry eh
    Once the engine cover is off there are some hose clamps and the bolts themselves
    holding the IC in place, not a hard job at all, in fact one of the easier jobs.
    Just take your time if you get stuck ask here and someone will help you out
    EDIT whats been leaking has been leaking over the life of the vehicle so far
  8. #7
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Thank you for the help. Yes I do have a factory rear locker. Is that the solenoid for that, that's i've read about. That apparently is the weak point in the locker.
  9. #8
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Unsure..
    Best way to find out is to trace the vac line from the rear diff to the engine bay and see where it ends
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    I'm confused ... I think???
    So the oil, shows me where boost can be leaking from, I reckon that's correct, is it?
    And we don't want oil, that's now supposed to go into the catch can right??
    So if I get rid of the oil and tighten/replace those clamps, I should be much better off.
    Is that all correct???
    Sorry if I sound a bit dumb, but as I say to others, it's dumber not to ask.
    Thank you all for the help.
  11. #10
    Yes... to all except the dumb bit.
    You have a new 'toy' it will take a while to suss out all its little pecadilloes so not dumb at all
