27th July 2016, 11:29 PM
lpg question
on my gu 4.5L my lpg gauge istn working propper, shows full when empty
any ideas how to fix so it reads correct?
cheers matt
27th July 2016 11:29 PM
28th July 2016, 12:49 AM
Check the wire hasn't shorted out to the tank sender.
LPG gauges are often fairly innacurate, but failures are usually the wiring or the gauge at fault
The Following User Says Thank You to Arfa Brayne For This Useful Post:
28th July 2016, 12:56 PM
X 2 agree with above it may just be a bad connection or a bad earth
1st August 2016, 10:21 AM
thanks guys
like yesterday was odd i drove 400 ks then had the alarms with flashing red light come on but had full green lights
my landrover discovery has an extremely acurate gauge for gas thats why i asked
one question i will ask can you get bigger tanks to fit under the gu?
1st August 2016, 10:45 AM
mattyk
thanks guys
I have a 105 Litre Useable Gas Tank in my 4.5
1st August 2016, 11:49 AM
I usually get around a 100 litres of gas in
Sent from my XT1068 using Tapatalk
