Results 11 to 20 of 22
Thread: 2 months with the Patrol
    Jul 2015
    Camden NSW
    6 Post(s)
    Quote Originally Posted by Fwdpatrol View Post
    Traction control in my MY 15 model, was horible in stock form
    It would take over going around a rounda bout and cut the accelerator
    It is the worst item i have ever seen
    At least i can turn it off
    The so called Nissan engineers simply have failed as have Nissan in general with over 15 years of the current GU patrol evolution Things that should have been fixed and enginered have had nothing done
    Example rear spring towers should have been reenforced as it is a know issue.
    But nothing.
    The GU patrol has the base to be a fantastic vehicle especially off road but has been left behind by Nissan in action.
    Totally agree with you. The TC in my 2014 is down right dangerous. I switch it off at all times except on mainly straight freeways or tollways. I had a bad experience on a fire trail once when in 2wd. Nearly pushed me off the road on a corner when I was only doing about 40klms. Bloody deadly. At least it cuts out when in 4wd.
    May 2016
    lower west victoria
    30 Post(s)
    I'm fairly sure the TC remains on (you can turn it off) in 4WD high. It does turn off in 4WD low automatically.
  4. #13
    May 2016
    lower west victoria
    30 Post(s)
    How real is the problem with the rear shock towers? I've read bits and pieces, what sort of load can be carried before they begin to become a problem?
  5. #14
    Usually no problem at all if you stay below GVM and don't drive like a tool on the tracks.
    Problem is that the payload of a Patrol is so low almost every vehicle that has Steel bars, Winch, Long Range Tankage and a set of Drawers goes over GVM as soon as one person gets in.
    Add a couple of people and the gear when you go tripping and maybe a Camper or Rooftop tent or gear on the roof rack and most 'loaded' Patrols you see on the road are 200 to 500 Kg or more over GVM.
    If you are into giving the vehicle a bit of a hard time (nothing wrong with having a bit of fun if that is what floats ya boat) then reinforcing the towers and/or laminating diffs etc is the way to go
  6. #15
    May 2016
    lower west victoria
    30 Post(s)
    So where do the towers give out? Is it up the top where the shock would push up and pull down?? Or someplace else??
  7. #16
    They rip the welds from the side of the chassis. @MudRunnerTD posted some pics of a tower failure, along time ago.
    One bolt on solution http://www.nissanpatrol.com.au/forum...=tower+failure
    The only problem I have with fitting these is that I have a 2" lift and the extra width of the plate will raise the rear beyond legal height, with out an engineering certificate.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    MudRunnerTD (2nd August 2016)
  9. #17
    Those are pics I found online.
    Vvvvv these are from my GQ
  10. #18
    May 2016
    lower west victoria
    30 Post(s)
    So it's the coils and not the shocks. Gee that looks pretty crappy.
  11. #19
    May 2016
    lower west victoria
    30 Post(s)
    That looks like the sort of thing you could get a bolt onable kit for to fit before that problem occured. It doesn't look like it would need alot of extra strength & support.
  12. #20
    Yes there is a couple of bolt in kits. Click on the link Mudnut posted above for info about n the Bolt in kit.
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudnut (2nd August 2016)
