5th August 2016, 07:58 PM
#21
Wheels and tyres on today.
285/75 on a 16 rim with neg 13.
Thanks for all the help.
The Following 2 Users Say Thank You to besp For This Useful Post:
jay see (6th August 2016), MudRunnerTD (1st November 2016)
5th August 2016 07:58 PM
7th August 2016, 10:20 PM
#22
besp
I hope a little lift is next on your list.
Sent from my XT1068 using Tapatalk
7th August 2016, 10:32 PM
#23
jay see
Yes it's sitting a bit tight.
I'm researching a 2" lift right now!
The Following User Says Thank You to besp For This Useful Post:
BigRAWesty (8th August 2016)
7th August 2016, 10:36 PM
#24
besp
Good, it doesn't look right ATM.
The Following User Says Thank You to jay see For This Useful Post:
31st October 2016, 08:23 PM
#25
jay see
I recently fitted 305/70/16 on 16x8 neg 13 on a series 1 GU.
Drivers side.
Passenger side.
This is with a 2" lift.
Adjustable panhards will recenter the diff, but as you can see it's not a lot.
Is this common? I just changed from the stock 17" alloys to 16x8 steel rims , no idea offset as I bought them used a few years ago. But I've noticed the same thing, drivers side hangs out past guards , passenger side doesn't
Sent from my HTC_0PKV1 using Tapatalk
1st November 2016, 09:43 AM
#26
Moderator
bsteveo
It's a Panard adjustment. This is the reason you need adjustable Panards when going taller than a 2" lift. The difference gets bigger the higher the lift.
Check out my Toy -->
Rogue Dung Beetle
jay see (2nd November 2016)
1st November 2016, 09:52 AM
#27
MudRunnerTD
Ah fair enough, thanks for that I thought I was going insane
