20th July 2016, 10:49 PM
#21
Throbbinhood
Was it a flat plug by chance? Really hoping to stick with a flat plug.
Yep, standard 7 pin flat socket, it is worth it for the LEDs that let you check that it is wired correctly without even connecting a trailer. On top of that it will make troubleshooting easier too
WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
The Following User Says Thank You to JME_GU For This Useful Post:
Throbbinhood (21st July 2016)
20th July 2016 10:49 PM
21st July 2016, 03:09 PM
#22
JME_GU
Was it this one mate?
24th July 2016, 06:15 PM
#23
Throbbinhood
That looks like it. There is enough room to run the standard trailer wiring plus a 25a cable. The screw down terminals are also big enough to accommodate the larger cable
25th July 2016, 10:10 AM
#24
Yep, worked a treat! Thanks @JME_GU
