14th July 2016, 03:34 PM
gu 4.2. 2004 coolent leak
hi guys just looked under my patrol an found a puddle of coolent so I got under it to have a look carnt find it anywhere looked on top under heater hoses looked at everything anyone had same problem////
14th July 2016 03:34 PM
14th July 2016, 05:22 PM
Park your patrol where you know it's clean,
you might of parked over someone else's problem
14th July 2016, 05:40 PM
Check your MAF sensor and disconnect the battery for a few hours.
The Following User Says Thank You to Hodge For This Useful Post:
14th July 2016, 10:34 PM
Patrol Freak
best way
go for a drive (during the day light hours) for about 1-2 hours, get it nice and warm
park in a nice clean area, and leave it for about 20 mins
come and check then
if there is any stains on the ground of fresh coolant
have a look in the engine bay for any wet spots, that will give you an idea on where to look, it may be a pin prick of a leak in a hose
but it WILL leave evidence and you can track it from there
also as TD said, you sure it wasn't there before you parked there?
Tidy Whitey - 99 GU TD42Ti - Diesel Gas, (GUIV Turbo & Intercooler 8Lb boost), 33" Micky T's Baja MTZ's, Dual Batt's, Cargo Barrier, rear draws, HID Super Oscars, winch, Grinch & witch attached and more goodies to come
15th July 2016, 10:26 AM
Normally you can smell coolant leaks, it may leave
a white residual powder where it was leaking to.
15th July 2016, 12:02 PM
Legendary
Have you checked your coolant level? If your not loosing coolant, it's not yours.
The Following User Says Thank You to 4bye4 For This Useful Post:
threedogs (15th July 2016)
