Results 1 to 8 of 8
Thread: Wanted EGT and Boost gauge
    Jun 2016
    Darwin, NT
    Hi Guys.
    I have a 2009 Patrol GU VI with the ZD30 motor. I need to get myself 1xEGT gauge and 1xBoost gauge. I was wondering if there were any recommendations and how to fix advise that I could get from you guys before venturing into the unknown...
    Thanks in advance!
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    as ET said in the other thread
    you have a CRD - so a Scan Gauge would be better for you
    have a look here, or go to scan Gauge them selves
    http://scangauge.com.au/
  4. The Following User Says Thank You to Bigcol For This Useful Post:
    Beetle Rox (12th July 2016)
    Jun 2016
    Darwin, NT
    Thanks a lot bigcol. I'm not familiar with scan gauges so that's why I was wondering if there was an alternative. Do you or ET have some tips on how the scan gauge should be fitted and what the best version would be suitable?
    Thanks again!
    330 Post(s)
    my understanding is they are a Plug and Play mate. they plug into the service port and give you a Heap of real time info on Boost, EGT, etc. I don't know much about them but i checked out the one in Growlers on a trip and was pretty impressed with the info he had at hand. Id go that way for sure!!
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Beetle Rox (13th July 2016)
  8. #5
    Not sure it give you real time EGTs, but most other would be available.
    Not sure where ppl mount them [Scan-Gauge] but my Ecu-Talk is mounted in front of the dash cluster
    About the onlt things I cant see is the trip meter and Clock,
    I think the Scan-gauge is a tad more slender
  9. The Following User Says Thank You to threedogs For This Useful Post:
  10. #6
    175 Post(s)
    Scangauge mounted in the little compartment under dash. Fit perfectly.
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #7
    Jun 2016
    Darwin, NT
    Awesome thanks guys! I really appreciate it. Which version of the Scangauge is best suited for the patrol please? Also I was interested in getting a EGT gauge, just to keep an eye on the temps.
  13. #8
    43 Post(s)
    Scangauge doesn't do egt.. only the boost and other things..
    Personally I've got the scangauge 2.
    But also have egt, boost and oil pressure gauges..
