Results 1 to 5 of 5
Thread: Running and tuning LPG and Dual Fuel.
    Running LPG and Dual Fuel.
    There are many threads dealing with problems from running Dual Fuel.
    I will try and deal with some commonly asked questions.
    Tuning for LPG
    I asked Alitis007 ( a very knowledgeable forum member) for timing, spark plug gaps specifications for a dual fuel RB30. This is his answer:
    "Timing is a bit fiddly because you need to find the happy medium between both fuels. Reason being that lpg has a higher octane rating than petrol so you need to advance (timing) slowly and drive the car and make sure it doesn't ping on either fuel.
    Don't alter the factory plug gap because that could cause a miss fire, you could put in a colder plug as lpg burns hotter, but if your motor burns oil using a cold plug is not ideal.
    The heat range of a plug is written in its part number, higher the number colder the heat range, as is other information like size, length, type and some other information irrelevant for now.
    As a example a BPR6E is colder than a BPR5E. Changing the heat range more than one number is not ideal either because you can severely alter the exhaust gas emissions of the car and possibly cause engine damage or premature failure.
    Without tools like a gas analyser that's all the information I can help you with."
  2. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    dom14 (5th July 2016), ithy (2nd December 2020)
    581 Post(s)
    New forum created and post copied to new section.
  5. The Following User Says Thank You to AB For This Useful Post:
    mudnut (3rd June 2016)
  6. #3
    LPG IS A DANGEROUS FUEL. IT IS RECOMMENDED THAT QUALIFIED PERSONS WORK ON AND TUNE GAS COMPONENTS.
    Some threads dealing with LPG.
    LPG MANUAL http://www.nissanpatrol.com.au/forum...ighlight=impco
    4.2 DUAL FUEL NOT IDLING http://www.nissanpatrol.com.au/forum...ghlight=timing
    GAS AND PETROL VS DIESEL http://www.nissanpatrol.com.au/forum...trol-vs-diesel
    FILTER TYPE http://www.nissanpatrol.com.au/forum...ighlight=impco
    RB30 NOT IDLING BUT OK ON PETROL http://www.nissanpatrol.com.au/forum...ighlight=impco
    TB42 GAS ISSUE http://www.nissanpatrol.com.au/forum...ighlight=impco
    TROUBLE STARTING AND BOGS DOWN ON PETROL http://www.nissanpatrol.com.au/forum...ighlight=IMPCO
    PICTURES OF TB42E SET UP http://www.nissanpatrol.com.au/forum...ighlight=impco
    GU TB45 ECONOMY http://www.nissanpatrol.com.au/forum...ighlight=impco
    IMPCO TEARDOWN. http://www.nissanpatrol.com.au/forum...ight=DUAL+FUEL
  7. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    Arfa Brayne (18th May 2021), dom14 (5th July 2016), ithy (2nd December 2020)
  8. #4
    Quote Originally Posted by JoshC1994 View Post
    Bump bump bump
    hey buddy,read your private message
  9. #5
  10. The Following User Says Thank You to mudnut For This Useful Post:
