5th July 2016, 08:31 PM
#11
Travelling Podologist
If you find a source (or part no.) for new scrivets let us know. When I had the same problem I ended up daubing a bit of windscreen mastic over each scrivet. A bit messy, but several years down the track it’s still keeping out the water, but it would be good to have a full set of scrivets for when the windscreen inevitably needs replacing.
5th July 2016 08:31 PM
11th July 2016, 10:48 AM
#12
hey guys if you go to nissan
i priced a set of scrivets $24.35 from nissan
to hold the scuttle pannel in
The Following 2 Users Say Thank You to mattyk For This Useful Post:
Bloggsy (11th July 2016), Cuppa (13th July 2016)
11th July 2016, 03:50 PM
#13
mattyk
Theres a small plastic plug you should also replace if your replacing those scrivets.
You need 7 scrivets and 4 of those plugs. And i bet you will break the small plastic scew at either end of the panel too. So should get those too just incase....
13th July 2016, 07:03 PM
#14
mudski
You wouldn’t have a parts diagram with part no’s would you @mudski ?
13th July 2016, 07:23 PM
#15
Has anyone got pics of doing the job?
Mine leaks bad and I reckon this thread has just taught me why
>>>tappin from tassie
Hello from Under Down Under!
13th July 2016, 09:37 PM
#16
Cuppa
mudski ?
mmmmmmmaybe
I'll have to look up your model just incase they are different to the early shape GU's.
13th July 2016, 09:52 PM
#17
Hopefully you can see the part numbers. They are the same throughout the GU series @Cuppa
13th July 2016, 09:58 PM
#18
taslucas
>>>tappin from tassie
@taslucas
This may be of help?
The Following 3 Users Say Thank You to mudski For This Useful Post:
Cuppa (14th July 2016), mattyk (16th July 2016), taslucas (13th July 2016)
14th July 2016, 09:32 AM
#19
Thanks Mark. Much appreciated.
I have copied them & stored away on my computer for future reference.
18th July 2016, 08:07 AM
#20
I'm getting water in on passenger to. It's coming through one end of the grab handle on the ceiling over the door.
From what's been said I'll investigate the sunroof side of things!
