Results 1 to 8 of 8
Thread: Brake Cleaner and part degreaser
    Sep 2011
    I was going to buy some brake cleaner as I am doing a full swivel hub and bearing rebuild and may as well put new seals in the brakes etc. Now what exactly is 'brake cleaner'? Is it just a degreaser by another name? I'm asking as I have a 5l of CT18 Truckwash. Can this be used a brake cleaner and indeed for parts washing for bearings etc as I dont want to buy 'brake cleaner' and 'parts washer' unless I really have to.......
    THoughts?
    Thx
    Tony
    White 1994 GQ Patrol Manual Diesel 4.2
    Jul 2016
    Brake cleaner is a degreaser but it dries radiply leaving no residue. Normal degreasers will leave a film, obviously no good on brakes or a lot of other jobs. Not sure that ct18 will be strong enough to get it clean. I find the cheap aerosol degreaser from super cheap works very well, better than a lot of other more expensive products.
    Sep 2011
    I've got several cans of that but am basically going to have a tub to put the parts in so need quite a lot. I saw they had 'parts washer' in Supershit but again is it just normal degreaser with a MUCH higher price tag.....
    Jul 2016
    If you need to bath the parts, diesel is the go. Cheap as compared to degreasers, needs a bit more elbow grease but its not $15 for 4 litres either.
    330 Post(s)
    The great thing about aerosol cans of degreaser is you can spray into the mess like a parts washer. I use a combination of canned degreaser and a parts washer.
    Brake cleaner is more aggressive I think, I don't use it a lot but when I do I glove up and ventilate. Carbi cleaner is worst again.
    Sep 2011
    Thanks guys, is petrol effective as well?
  8. #7
    North brissy
    Quote Originally Posted by flashman1207 View Post
    Yes. I use petrol a fair bit. Its cheap. Clean all the heavy stuff off in the petrol then final clean with break cleaner or a shellite.
  9. #8
    Sep 2011
    thanks guys
