Results 1 to 5 of 5
Thread: Westy's Tillix Setup and Rundown
    43 Post(s)
    Ok so tillix is in..
    Sooooooooooo easy..
    Crazy easy..
    Still some micro tuning to do but very happy..
    19-20 max boost and 16 @ 110.
    That 16 @ 110 is what I want to reduce a smidgen so will fiddle a little more with needle valve. @mudski your spot on about the needle valve..
    1/8 turn goes from what I have atm to 15psi max, laggy as hell and egt's sky rocket..
    But overall for the money it's a top kit..
    I tig welded the socket onto the intake pipe, and tapped a threaded barb into the intercooler for boost gauge..
    https://youtu.be/7tQziIey884
  2. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    AB (2nd July 2016), Woof (2nd July 2016)
    462 Post(s)
    For some reason I thought you had a direct injection motor. But yeah. Theres no point at all just putting in the Dawes or Tillix. The needle valve is where you get the performance.
    BigRAWesty (2nd July 2016)
  6. #3
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    Just made this thread Sticky Westy, I am sure it will come in very handy for members mate..........well done
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  7. The Following 2 Users Say Thank You to Woof For This Useful Post:
    BigRAWesty (2nd July 2016), Sir Roofy (2nd July 2016)
  8. #4
    43 Post(s)
    Quote Originally Posted by Doggy View Post
    Thanks mate.. hopefully I've done it right lol
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
  10. #5
    I used this hose for the boost line, note it has clamps for each connection,
    If I ran out of clamps I had blue cable ties on hand to achieve the same thing
    http://www.ebay.com.au/itm/1-5M-4MM-...oAAOSwlPRTbMjq
  11. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (3rd July 2016)
