Results 1 to 10 of 10
Thread: Brake Oil is Leaking!
Hybrid View
    Legendary dom14's Avatar
    38 Post(s)
    Hi Guys,
    I just discovered the my RB30 PATROL needs some attention with the brake plumbing system.
    Apparently there's a leak between the master pump and the brake booster.
    The oil is visible on the brake booster body behind the brake master pump, and has been slowly dripping down the booster outer body towards bottom end of the engine bay. It's not gushing oil out, but still bad enough to cause the brake warning light to come one on when I brake suddenly or take sharp bends.
    I topped up the brake oil on the master pump for the time being.
    What is the likely cause?
    How should I approach on fixing the oil leak?
    Thanx in advance for any advice, help, etc.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Check out the price for a master cylinder kit from vendors on this site or eBay. Don't let it go or it may fail completely and suddenly.
  3. The Following User Says Thank You to 4bye4 For This Useful Post:
    dom14 (28th June 2016)
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Hi!
    I have had the same situation when the cap of brake master cylinder where broken.
    Check the cap firstly.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  5. The Following User Says Thank You to Wine_maker For This Useful Post:
    38 Post(s)
    I gave it a wash and checked to see whether it's still leaking, but it I can't see any oil marks yet.
    It's a very slow leak by the looks of it. Touching around the joint between booster and master cylinder
    didn't produce any oil residue on my fingers.
    I'm wondering,
    Is there a way to fix this by replacing a(the) seal between master cylinder line between the booster &
    the master cylinder?!!!
    Cheetah Outreach
    Ballarat, Vic
    174 Post(s)
    If he’s not too tied up in Kalgoorlie at the moment I think Pearcey is the man to advise on this.
    @pearcey
  8. The Following User Says Thank You to Cuppa For This Useful Post:
  9. #6
    38 Post(s)
    @pearcey
    Thanx mate.
    I sent him a PM, Hopefully, he's in an area where he can receive it.
    Dom.
    Cheetah Outreach
  10. #7
    Sep 2011
    adelaide
    18 Post(s)
    G`day Dom
    Sorry this is a bit late but I`m in the middle of WA and the coverage is sparse.
    Looking at your problem,the master cylinder is leaking past the rear seal.
    I would suggest that a new cylinder be fitted,(yes kits are available, but if the bore is damaged in any way they should not be honed as there is a corrosive resistant coating and this is removed when honed) There are companies that fit stainless steel sleeves to the bore but these do wear out over time, but are a very good alternative to a new one (depending on price)
    Personally I would fit a new one as it should last at least 7+years
    Hope this is some help.
  11. The Following 2 Users Say Thank You to pearcey For This Useful Post:
    Col.T (11th July 2016), dom14 (7th July 2016)
  12. #8
    38 Post(s)
    Quote Originally Posted by pearcey View Post
    G`day Dom
    Thanx pearcey.
    I gave it a good wash last week and have been monitoring it since then.
    I'm yet to see or feel any leaking oil from where it showed the leakage.
    I'm picking up a new one anyway.
    I'm thinking about waiting to see how long it takes to see the leakage.
    Also keeping an eye on oil level. I put a mark on the reservoir so I can notice it easily.
    Dom
    Cheetah Outreach
  13. #9
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day fellas,
    not much to say after Pearcey's reply but having had, over the years about God knows how many leaking brake master cylinders, they show up in the strangest of places.
    Really, the sums are simple. If you're losing brake (or clutch) master fluid look for the leak, as you've done Dom.
    Anywhere up high, it's the master, anywhere down low it's the slave.
    New replacement usually was emy choice but regardless, do something as it will only get worse.
    Rgards,
    Col
  14. The Following User Says Thank You to Col.T For This Useful Post:
    dom14 (23rd July 2016)
  15. #10
    38 Post(s)
    Quote Originally Posted by Col.T View Post
    G'day fellas,
    Rgards,
    Col
    Thanx mate. Yes, that's what I'm doing. I'm replacing it, as it's not worth the trouble trying to rebuild them.
    Cheetah Outreach
