Results 1 to 4 of 4
Thread: Trouble getting altenator bolts in
    Mar 2016
    Canberra
    Hi
    Changed the AC, PS and altenator belts today on my 99 TB45E. However, I can't get the two 10mm altenator bolts (top and bottom) back in. They just won't grab when I turn them. Anyone else had this issue and what solved it. Getting a bit frustrated. Will go back and have another go
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    You haven't mixed the bolts up with something else
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Use a phillip head screw driver to centre one hole and then you can lever the alternator with it to get the other hole matched up.
    Have you taken the tension off the pulleys..Also use a bit of the correct locktite as well
