26th June 2016, 08:24 PM
Trouble getting altenator bolts in
Hi
Changed the AC, PS and altenator belts today on my 99 TB45E. However, I can't get the two 10mm altenator bolts (top and bottom) back in. They just won't grab when I turn them. Anyone else had this issue and what solved it. Getting a bit frustrated. Will go back and have another go
26th June 2016 08:24 PM
27th June 2016, 01:28 PM
You haven't mixed the bolts up with something else
27th June 2016, 03:44 PM
Use a phillip head screw driver to centre one hole and then you can lever the alternator with it to get the other hole matched up.
27th June 2016, 05:59 PM
Have you taken the tension off the pulleys..Also use a bit of the correct locktite as well
