Should be two 12mm bolts holding in each seat if you require covers once removed ,give me a PM.
Also unbolt the top of belt and push it through the top slot in the moulding
Also dont forget to post an intro,,, just something the forum asks of us all, no harm done though,,, enjoy
not sure if they are the same as my 2005 GU, but if it is there might be a pull loop bottom rear of seat that you pull on to disengage latch under seat. Then there are 2 bolts close to side wall under pull off plastic covers that you need to remove. then remove seat.
hi mate, just a little something we ask of new members here is can you please jump over to the introduction thread and tell us a little about yourself. im sure someone will be along to answer your question soon enough. oh, and you might want to mention if its a Y61 or Y62
