Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
Thread: Non-Patrol extendable towing mirrors
  1. #51
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I'm at our son's place in McLean VA. it's a few kms outside Washington DC, next to Langley where the Bush Intelligence Centre is i.e. the CIA..
    I've bought a trans overhaul kit as well as other bits and pieces. I'm lucky my son works for the World Bank so I can post it all back for free No room in the suitcases and I need to buy more stuff in LA on the way back home..
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    MB (11th August 2016)
    472 Post(s)
    One World coming home is the go mate, Qantas have kindly snuck us up a 'mineral' to 'Sapphire' ;-)
  5. #53
    Expert janderson's Avatar
    Bearii Vic
    3 Post(s)
    BettaView ® Caravan Towing Side Mirrors Foldable Extendable GU NISSAN PATROL
    1 x PAIR OF TOWING MIRRORS TO SUIT
    1997 TO CURRENT NISSAN PATROL Y61
    ADR RULES(Australian Design Rule 14/02 Rear Vision Mirrors) 2006.
    Where the lower edge of an exterior mirror is less than 2 m above the ground when the vehicle is loaded to its technically permissible maximum laden mass.
    15.2.2.6. Where the lower edge of an exterior mirror is less than 2 m above the ground when the vehicle is loaded to its technically permissible maximum laden mass, this mirror must not project more than 250 mm beyond the overall width of the vehicle measured without mirrors.
    1st G60 Then MQ Now GU
  6. #54
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by janderson View Post
    Nice area your from mate , not sure what the post is about but for a GU you can buy clearview mirrors which comply to all regs or buy yourself a cheap set of Silverado 2007 mirrors from the states and adapt them to fit the GU which plenty here have done .
    There is also a maximum distance they can stick out when not towing .
  7. The Following User Says Thank You to GQtdauto For This Useful Post:
    janderson (8th March 2018)
  8. #55
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    Quote Originally Posted by shakey55 View Post
    I've read all this thread and was still a little confused about legality, so I read the clear view website and found this. Still not totally convinced so I will make further inquiries before purchasing
    http://clearviewmirrors.com.au/pdf/CC_NPGU.pdf
    Could you just print this and keep in the glove box and produce it if the mirrors ever come into question?
    Cheers,
    Evo
