21st June 2016, 12:21 PM
Cruise control SET light flashing on dashboard
Hey guys,
As i haven't used it in a while i've only noticed recently that my cruise control is not working, when i turn it on the set light on dashboard just flashes. I'm thinking its either after the heavy rain storm we had 3 weeks ago and waters got in somewhere maybe shorted something out. My patrol was in the outside airport parking at Coolangatta for that weekend. Or i've just recently got my oil change at local mechanic and they've done something, cant see how that would affect it tho. but i only noticed it wasn't working after these 2 things happened. Also, im not sure but i thought the red led on my trailer brake box thing used to come one when i braked, and now there is nothing.
Any advice on what it may be would be great thanks. I've had a search on the forum but cant seem find anything exactly the same, my searching skills are not the best tho.
Thanks for any info.
21st June 2016 12:21 PM
21st June 2016, 12:26 PM
Have you had a look under for any wires that may have been knocked loose???
21st June 2016, 12:29 PM
Haven't, but thats probably a good start!
The Mrs has the car everyday at work at the moment so never have time to check it but i'll have to check when she gets home later.
21st June 2016, 12:38 PM
Check if your brake lights are working. If there not check if the fuse is blown.
The Following User Says Thank You to Yendor For This Useful Post:
21st June 2016, 12:56 PM
could be a few things. stop light switch, fuse id start with them first
The Following User Says Thank You to Mudveins For This Useful Post:
21st June 2016, 02:16 PM
I am he, fear me
There are two switches on the Brake pedal... one is for Cruise and one is for stop lights, both powered from the same fuse as Rodney mentioned.
So agree with others, check the Brake Lights for operation, I'm tipping the fuse is blown
Maybe the rain got into the Trailer Plug or sumthin'
The Following User Says Thank You to the evil twin For This Useful Post:
22nd June 2016, 06:38 PM
Hey,
So brake lights arent working when i push brake pedal but if i push the button on the electric trailer brake module thing they come on, Ive checked fuse its fine, globes working when i push the trailer brake switch. Ive looked under pedal everything under there seems to be fine by looks of it, i can see the 2 switches that the brake pedal sits on they look ok. Not sure what else to check?
22nd June 2016, 07:30 PM
#8
How did you checked the fuse? Did you try replacing the fuse?
22nd June 2016, 07:35 PM
#9
Yendor
yeh replaced it still not working
22nd June 2016, 07:47 PM
#10
juzzs8
What was the fuse number?
