Results 1 to 7 of 7
Thread: Which patrol to buy
    Jun 2016
    Which patrol to buy
    Hello mozzy here.keen to buy patrol but unsure which one. Like manual, turbo diesel but nothing to high tech. Currently own a 60 series cruiser .not happy with it but like the simplicity of the vehicle not much goes wrong but if it does I can work on it. Are the 3 ltr turbo diesels around 1999 ok.
    43 Post(s)
    Welcome mate..
    In short no 3 ltr is simple..
    The DI is sorta simple, direct injection etc but still is very ecu reliant. And the crd is more advanced again..
    If you want a simple mechanical engine look at the 2.8 or 4.2.
    these guys are all mechanical..
    Jun 2016
    Thanks Kallen
    Excellent info
  5. The Following User Says Thank You to Mozzy For This Useful Post:
    BigRAWesty (17th June 2016)
    Expert Dan02's Avatar
    Apr 2016
    Petre, Bris, QLD
    Hello Mozzy
    I looked for months, bit fussy, procrastinating etc, looked at both 2.8 and 4.2 but ended up with the 4.2 - I recon there both great
    2001 Patrol 4.2TD manual 2" lift; Beaudesert 3" Exhaust
    Jul 2016
    Can't really go too far wrong with a 2.8 or 4.2. All little knowledge of their weaknesses goes a long way to making them ultra reliable. The 3.0, no idea where to start on their weaknesses, too many to make it a solid engine. Sorry if that upsets a few but I've done major repairs on too many to be a fan.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    considering the amount of 3.0L on the roads V's how many have gone bang
    I think the D4D3.0L of the toyotas is a far worse motor - injectors, oil cooler, turbo, weak heads - the list is endless with them
    there are some Di that are bad, but not enough to say a specific year or model is crap
    I think a lot has to do with how they were looked after brand new - luck of the draw so to speak
    I've got some mates with large Kms on their Di's with out a problem from new
    if you are going to be doing a lot of towing, then a TD42 is worth the money
    if your going to be using it as a daily driver, then the RD28 is ok, but not a rocket ship off the line
    if you want an all rounder (good fuel, quick enough, tows small trailer) then the ZD30 is a good pick
    even the later CRD's are a good all rounder
    my advice - think about what you want to do with it first - then look at what suits your lifestyle
  9. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    BigRAWesty (2nd July 2016), morton2478 (2nd July 2016)
  10. #7
    Mar 2016
    As long as you anti grenade them mate they can be good.
