Page 1 of 8 123 ... LastLast
Results 1 to 10 of 77
Thread: Long Range Petrol tank access issue
Hybrid View
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    I'm in the process of pulling out the 70 litre long range custom tank in my GQ RB30 Patrol.
    Tank was installed quite a long time ago by the looks of it. (twenty years or more I reckon).
    I'm pulling it out to diagnose a possible loose power connection to the petrol pump or possible intermittent pump issue.
    I discovered it is a real PITA job to remove this custom long range tank as it's a tight fit.
    I'm wondering,
    1)Does it make sense to make a new pump access point from the floor above for future accesss ?
    By the looks of it, the petrol pump is just under the right hand side rear seat.
    So, I'll be looking at removing the rear seat, carpet and cutting a hole on the floor and make the proper removable plate to cover the hole.
    Is it worth it or is it an overkill?
    2)Is the petrol pump the same as the original factory one? Do they simply use the factory petrol pump with the custom made Long rank tank? Do I need to pull the petrol pump out of the tank to find that out?
    3)Are there any external pumps from other vehicles that i can adapt for this RB30 Patrol?
    Long Range Automotive(LRA) were the people who installed the tank.
    Thanx in advance for any advice.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    with making a new hole in the floor -
    are you expecting to take the tank / pump out again or not for another 20 years...........?
    have a think
    easier access, yes
    but
    the time to cut a hole, in the right place - correctly
    making a cover for it
    making it sealed (for fumes and dust and water)
    is it really worth all that work................................
    with the petrol pump.............
    as the GQ's never came factory with an Aux fuel tank, so there wont be an original pump in there
    unless
    they have taken one from a main tank
    or it could be any type of fuel pump - you will have to pull it out to find out what type it is
    I would be hoping they used the one out of the original main tank myself............
  3. The Following User Says Thank You to Bigcol For This Useful Post:
    dom14 (16th June 2016)
    38 Post(s)
    It's pretty damn hard to pull the tank out. Front bolts took ages to get them out.
    Everything's out, but I still can't pull it out in that tight fit.
    There has to be a certain way that I need to tilt it to get it out.
    If I put a brand new pump I won't have to worry about cutting access holes on the floor.
    But, I won't be putting in a brand new pump. It's way too expensive.
    If the pump is faulty, I have to see whether it's fixable.
    If not, I need to get a used replacement or rather I prefer
    an external pump, assuming there's such thing to suit the RB30 carby patrol.
    Cheetah Outreach
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    if it was me.... i 'd put a new pump in, make sure tank is clean inside, check the wiring and replace if needed. put tank back. ignore for another 10 years. cutting holes is a pain,
  6. The Following 2 Users Say Thank You to garett For This Useful Post:
    Bigcol (16th June 2016), dom14 (16th June 2016)
    38 Post(s)
    Quote Originally Posted by garett View Post
    Yeah, that's true. Cutting a hole is not easy considering the spot. I prefer an external pump, but it doesn't appear to be a solution without some fiddling.
    Cheetah Outreach
    Jul 2014
    6 Post(s)
    Hey Dom,
    Need to get that big fuel filler hose right out of the way, then lower the rear end of the tank first, then slide backwards under the diff. It's a real PITA.
  9. The Following User Says Thank You to Throbbinhood For This Useful Post:
  10. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Looking at your pictures, it looks like it's the plumbing at the rear of the tank that's stopping the tank from coming out or is the rear of the tank sitting hard up against the diff?
    The wire harness in your pictures from the fuel pump will more then likely run down to the rear of the vehicle and connect to the original fuel pump wiring harness (where the original fuel tank was) have you checked these connections?
    My guess is they used the original fuel pump and sender unit from your original fuel tank. You should be able to pick up an aftermarket fuel pump as a direct replacement.
  11. The Following 2 Users Say Thank You to Yendor For This Useful Post:
  12. #8
    38 Post(s)
    Thanx mate. It's a pretty tight fit. Tank is only few millimeters from touching the drive shaft. Driveshaft had to come out. Yeah, the wires connect the wire harness at the back of the vehicle under the LPG tank. I did check, but it's pretty hard to make sure whether the connections are dodgy, 'cos they appear to be permanently crimped connectors. 'Cos the problem is intermittent, I thought it's best to rewire the connections from the pump to the front of the vehicle with new wires and a conduit.
    An aftermarket fuel pump should be ok I reckon. I checked fleabay yesterday, but couldn't find a one.
    I'll try the local spare part shops today.
    I like the idea of having an access hole, so I can carry a used pump in case it needs replacement in future. But, cutting a hole is easily said than done.
    I'll post the outcome soon.
    Cheetah Outreach
  13. #9
    Jul 2014
    6 Post(s)
    Given yours is carby, why not run an external pump? Easy to change and you won't have to drop the tank again if it goes kaput.
    Whoops, missed your post above mine.
  14. #10
    38 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    Yeah mate, but I have to find a pump that's suitable, pressure wise. I'm not sure I can use any pump.
    For example I'm not sure whether I can use an external(or even internal) pump from R31 Skyline or a VL Commodore.
    I think EFI pumps are high pressure pumps, probably not suitable for carby RB30.
    I most certainly have to fabricate an adapter plate for the top of the tank as well.
    Cheetah Outreach
