Results 21 to 30 of 32
Thread: Interesting test on post 2 micron fuel fiters
    Jan 2014
    Shepparton VIC
    Quote Originally Posted by MyGU8 View Post
    For information and future reference:
    Bosch CP3 pump information (particularly the maximum pressure difference across the filter prior to change)
    http://www.boschdieselcenter.com.sg/...tem-cr_eng.pdf
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  2. The Following User Says Thank You to MyGU8 For This Useful Post:
    MudRunnerTD (15th June 2016)
    Jan 2014
    Shepparton VIC
    answer to a flow rate question, note CRD pump is actually CP1H rather than CP3
    Only an indication, may not be related to CP3 in Patrol CRD's
    Inside The Bosch CP3 Injection Pump - Diesel Power Magazine
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  5. The Following User Says Thank You to MyGU8 For This Useful Post:
  6. #23
    Jan 2014
    Shepparton VIC
    Ron1n,
    The flow rate is irrelevant to some extent, what I mean by this is I understand the fuel filter is to be sized to match the required fuel flow, but if the pressure is climbing up to 0.3bar after the filter then the engine/pump is not getting enough fuel. So it is VERY VERY important to monitor the pressure (this is the method of Bosch diagnostic as well).
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  7. The Following User Says Thank You to MyGU8 For This Useful Post:
  8. #24
    Jan 2014
    Shepparton VIC
    I think I am up to something here:
    You can add as many filters as you want to the system, the key point is not to worry about the flow rate but to monitor the pressure drop.
    The best way to do this is to measure the pressure (vacuum) with the original system after the OEM filter first.
    Install the second filter and monitor the vacuum and make sure it is reasonably within the limits (say 0.1bar or say 2psi more than the original).
    YEAH..............!
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  9. The Following User Says Thank You to MyGU8 For This Useful Post:
  10. #25
    Jan 2014
    Shepparton VIC
    OK.. here's the sketch explaining the proposed method installing a second filter.
    How can this be practically configured?
    1. First I would suggest to fit a (diesel) vacuum gauge after the OEM filter and monitor values, preferably before the recommended filter replacement interval.
    2. Measure the vacuum just after the filter change - this will give us two things
    - a compartive headloss across the filter on a clogged filter and
    - the vacuum level with a clean filter
    3. If the head difference is more than 0.3bar (according to Bosch) you have some serious issues with the fuel you are buying. You must consider changing the filter more often.
    4. If the head difference is less than 0.3bar you can proceed with the second filter installation.
    5. Measure the head just after second filter installation and make sure it is well below the 0.3bar compare to the measurement in 2 (OEM clean filter only measurement).
    6. Continue monitoring the vacuum gauge and when the head reduce to more than 0.2 bar (for safety) from the clean OEM filter only measurement (2 above) then time to change the filter(s).
    Note that the measurements are best taken at maximum safe load
    Usual disclaimer: these are based on my findings on the internet and does not mean accurate. I take no responsibility for any damage in any form caused by these information. I put this here for the sole purpose of my own benefit and future reference.
    USE AT YOUR OWN RISK
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  11. The Following User Says Thank You to MyGU8 For This Useful Post:
  12. #26
    Jan 2014
    Shepparton VIC
    picture for the above post
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  13. The Following 2 Users Say Thank You to MyGU8 For This Useful Post:
    MudRunnerTD (15th June 2016), nissannewby (15th June 2016)
  14. #27
    Nice work mere I will have a read. We have a great vendor that sells the filter setups at a great price too.
  15. #28
    Jan 2014
    Shepparton VIC
    Next step:
    Ford 7 3L Diesel Fuel Filter Vacuum Indicator Switch E8TZ 9S283 A Factory | eBay
    As it will be fitted to a barbed 'T' after the genuine filter, I need to figure out the grounding for this unit :-?
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  16. #29
    Jan 2014
    Shepparton VIC
    This is one of the reasons I went with Racor second filter rather than water watch.
    Why only watching for water when you can block AND watch...?
    https://www.youtube.com/watch?v=F_P7A3-i5nw
    That's it for now....
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  17. #30
    Jan 2014
    Shepparton VIC
    Not really a Bosch CRS1 - but I wouldn't think Delphi would be significantly different to Bosch given the similarity in Common Rail technology.
    The interesting point to note is the OEM 2 micron filter rating.
    https://www.delphiautoparts.com/en/t...-injector-how/
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
