Results 11 to 20 of 28
Thread: which high lift jack should i get
    Quote Originally Posted by Gav72 View Post
    I should say i'm after a jack for changing tyres, not vehicle recovery...
    I have used my exhaust Jack to change a heap of tyres. Fast, easy. No Brainer. I have used it once in a soft Sand Beach recovery of a very bogged navara last year.
    MB (11th June 2016)
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    You don't currently have a jack for simple tyre changes? Buy a hydraulic bottle jack from supercheap or alternatives....done. For changing tyres on the beach or track somewhere as said already exhaust jack. But usually with steel wheels if you can drive / winch to a flat safe firm ground the hydraulic jack will work as well.
  5. The Following User Says Thank You to sooty_10 For This Useful Post:
    MB (12th June 2016)
  6. #13
    583 Post(s)
    You don't currently have a jack for simple tyre changes? Buy a hydraulic bottle jack from supercheap or alternatives....done. For changing tyres on the beach or track somewhere as said already exhaust jack. But usually with steel wheels if you can drive / winch to a flat safe firm ground the hydraulic jack will work as well. Sent from my SM-G925I using Tapatalk
    Exactly! MB and myself can confirm you can change a 35" tyre on hard ground with an inch digging out the ground under tyre with GQ Nissan oem Jack.
  7. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (12th June 2016), Rock Trol (11th June 2016)
  8. #14
    But that is what Hi-lifts are, IE a Recovery Jack.
    Please, please, do not use a Hi lift to change out flat tyres... unless your will is up to date or you have awesome medical cover and know a good panel beater.
    The only even remotely safe way is to lift the wheel using a "wheel mate" for the Hi Lift then lower with extreme care onto an axle stand, change the wheel and reverse the process.
    An air bag can be used in a much safer manner for that purpose and you don't need the jack points in your bar work necessary for a Hi-lift
  9. The Following 6 Users Say Thank You to the evil twin For This Useful Post:
    AB (11th June 2016), Bigcol (12th June 2016), Chubba (11th June 2016), MB (12th June 2016), Rock Trol (11th June 2016), Rossco (11th June 2016)
  10. #15
    I have 3 Hi lift jacks and love them to bits I only used one last week.
    I have a Trewalla ,a Hi-lift and a TJM OX branded one, ohhh where did I
    use it,,,,,,,,,pulling my neighbours front fence posts out they are the best for that lol
    But they are dangerous always leave the handle UP or you'll end up breaking your jaw
    or worse. IMHO I cant see the need for them on modern [plastic] 4x4s.
    The taller ones are worse as they wil bend with any weight on them.
    Go buy an exhaust Jack and practise at home before you actually need to use it
    EDIT dont forget a jacking plate min,,,300x300x6mm plate
  11. #16
    WA Wheatbelt
    23 Post(s)
    This is my preference.....
  12. The Following 3 Users Say Thank You to DX grunt For This Useful Post:
    Bigcol (12th June 2016), MB (12th June 2016), mudnut (12th June 2016)
  13. #17
    475 Post(s)
    Ripper! What brand is that DXgrunt? AB and our families are heading out of the high country this September for a long awaited return to the beaches of Fraser, gonna need one of them with us for sure :-) !
  14. #18
    I have had a hilift bend under load. It is now relegated to wire straining and post pulling. Bloody dangerous pieces of kit.
  15. #19
    465 Post(s)
    If you can find one. Trewalla is the best. Or the HiLift from ARB. I wouldnt bother with any other brands.
  16. #20
    eBay Mark. Under $120
  17. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (13th June 2016)
