Results 1 to 9 of 9
Thread: 60 thou plus of lash in rockers TD4.2
    Mar 2015
    ok this is for the brains out there do you think that would cause a knock in the motor ??????
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Not so much a knock but a bloody hell of a rattle.
    Mar 2015
    thats what i was thinking also lot of white smoke like unburnt fuel
    North brissy
    Wont be helping. They should be at 0.35mm. So 60 thou is over 1mm
  6. #5
    Mar 2015
    hmmmmm having a bastard of a time trying to get tdc on one on my own doing this
  7. #6
    Hardcore
    central coast nsw
    2 Post(s)
    1.524mm , yeah way over spec not good at all.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  8. #7
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Mine were about that..
    Took it back to spec and dam..
    Gained a few Kw it felt like..
    Advanced
    Jul 2016
    Get the injectors tested to start with. White smoke is fuel burn propergation timing. Not necessarily injection timing. Can be caused by quite a few thing. I would start with bench testing the injectors and a visual check of the pre combustion chamber thru the injector opening
  10. #9
    Mar 2015
    new injectors
    I never go into the outback with out a decent supply of water,
    and the general rule for how much you'll need is three litres
    per day , per person, per man per degree over 25 degrees
    celcius, per kilometer if walking on foot, in the winter months
    dividing it by two, plus... another litre... at the end .... Russell Coight
