11th June 2016, 02:56 PM
60 thou plus of lash in rockers TD4.2
ok this is for the brains out there do you think that would cause a knock in the motor ??????
11th June 2016 02:56 PM
11th June 2016, 03:52 PM
Not so much a knock but a bloody hell of a rattle.
11th June 2016, 03:56 PM
thats what i was thinking also lot of white smoke like unburnt fuel
11th June 2016, 04:18 PM
Wont be helping. They should be at 0.35mm. So 60 thou is over 1mm
11th June 2016, 04:27 PM
hmmmmm having a bastard of a time trying to get tdc on one on my own doing this
17th June 2016, 02:59 AM
nissannewby
1.524mm , yeah way over spec not good at all.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
17th June 2016, 06:49 AM
Mine were about that..
Took it back to spec and dam..
Gained a few Kw it felt like..
1st July 2016, 06:47 PM
Get the injectors tested to start with. White smoke is fuel burn propergation timing. Not necessarily injection timing. Can be caused by quite a few thing. I would start with bench testing the injectors and a visual check of the pre combustion chamber thru the injector opening
3rd July 2016, 05:16 PM
I never go into the outback with out a decent supply of water,
and the general rule for how much you'll need is three litres
per day , per person, per man per degree over 25 degrees
celcius, per kilometer if walking on foot, in the winter months
dividing it by two, plus... another litre... at the end .... Russell Coight
