Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 2006 GU 4.2 oil filters
    North brissy
    JJF made one himself. He has some info on it floating around.
    330 Post(s)
    Quote Originally Posted by Snafu View Post
    Chicken has changed his design, slightly different to mine.
    Yes the MK1 version I fitted to my GQ did not fit the GU. (I bought 2) I waited about 3 years for the MK2 version to be developed to fit the GU series. Great bit of kit.
    @Hodge. Look up ProDiesel Motorsport on FB, he may have them in stock.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Hodge (11th June 2016)
  5. #13
    Expert Gary Vansleve's Avatar
    Sep 2013
    Brisbane
    Regarding the oil filter question I just cut the bottom out of a 1 litre oil container leaving about a 25 mm lip. As posted above I let it drain overnight then do the filters. The first time I did this super mod a mate snuck up behind me an tickled me nuts as i was precariously perched over the guard an I spilt the bloody oil everywhere bloody hell.
    All jokin aside it has worked every time I have done an oil change.
    Cheers Gary
    [/SIGPIC]The old girl like me well past the use by date
  6. #14
    175 Post(s)
    Last time when undoing the filters oil went farkin everywhere.
    I was thinking this time might jack up the passenger side so the filters are as upright as possible to contain the oil within them? Just a brainstorming idea.
    330 Post(s)
    I am mates with Chicken on Facebook and have sent him a PM. Not sure if he is in Au or Indo at the moment. I think he is on a swing in Indo though, I'll let you know.
  8. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  9. #16
    175 Post(s)
    Thanks Darren. I PM-ed that ProSport Diesel page/bloke you mentioned, no reply as yet.
  10. The Following User Says Thank You to Hodge For This Useful Post:
    MudRunnerTD (12th June 2016)
  11. #17
    330 Post(s)
    ProDiesel Motorsport. Yeah Matt is a Great bloke mate, if he has them he will sort you out.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Hodge (12th June 2016)
  13. #18
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Here's the one I made from some scrap colourbond guttering. It's lower than the ones you can buy and has the offset drainage because of the bigger starter I'm using.
    John
  14. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    BigRAWesty (12th June 2016), nissannewby (12th June 2016)
