4th July 2016, 10:48 AM
Removed my Gas system and now the car wont start
G'day team,
removed my Gas system and motor as i bought it with a blown motor.
All back together now and it won't start. It cranks but i can't get spark.
Any idea's?
4th July 2016 10:48 AM
4th July 2016, 10:58 AM
Sorry forgot to mention its a tb42e GQ TI
4th July 2016, 11:20 AM
Is there a solenoid in the fuel line?
4th July 2016, 05:29 PM
Re trace all your wires , seems you've missed something and it may be visible
4th July 2016, 07:04 PM
Most GQ gas installations have a relay fitted in between the ECU relay and injectors. This will turn off the injectors when running on LPG but shouldn't affect spark.
This relay can either be mounted near the ECU relay (beside the battery) or near the head on the front of the engine.
During the gas installation they cut the wire running between the ECU relay and injectors. When removing an LPG system you need to find where they have cut this wire and rejoin it and remove this extra relay.
The Following 4 Users Say Thank You to Yendor For This Useful Post:
AB (4th July 2016), dom14 (5th July 2016), General (5th July 2016), mudnut (4th July 2016)
4th July 2016, 07:23 PM
Nasty Dog - Moderator
Welcome to the forum, can you post up an introduction, it is something that we request before getting access to the manuals.
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
The Following User Says Thank You to Woof For This Useful Post:
4th July 2016, 09:44 PM
Thanks guys chewing through this info as we speak, as well as the manuals to see it it will make sense. The wiring was wierd it was like it was all piggy backed which doesnt make sense to me. there has to be a circut still open somewhere
#8
Cheers mate, sorry I thought i did it when I joined. Done now
The Following User Says Thank You to General For This Useful Post:
4th July 2016, 09:48 PM
#9
General
All good mate, hope that you find the issue and solve it, thanks
5th July 2016, 03:12 PM
#10
Found it, A dodgy earth off the back of the coil. whilst it was earthed it was not earthed well enough. Persistence pays off.
