Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 98 GU knocking noise in front end of engine
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    depending on how hot the engine is - the fan should stop pretty much straight after the motor is turned off
    if it keeps spinning, that hub is roo ted
    Beginner npw112's Avatar
    May 2016
    Canberra
    Yeah I just did some research and it appears to be called a "Viscous Fan Clutch Coupling".
    Further reading shows that they are filled with oil which might explain the leaking fluid I noticed.
  4. #13
    May 2016
    Canberra
    Quote Originally Posted by Bigcol View Post
    It does it just comes some "slow down spins" once the engine is off and it is during these spins that the noise is still there.
    I just manually spun the fan and the noise is there
  5. The Following User Says Thank You to npw112 For This Useful Post:
    mudski (2nd June 2016)
  6. #14
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    any more than 1 full rotation of the Fan as soon as you turn the motor off, means the Hub is cactii
    and if thats where the noise is coming from - bonus - needs to be replaced anyway
  7. The Following User Says Thank You to Bigcol For This Useful Post:
    mudski (4th June 2016)
  8. #15
    472 Post(s)
    Quote Originally Posted by npw112 View Post
    Hi Guys, Looking for some advice here. My 98 GU has 430,000KMS on it, a 4.5 petrol, manual and runs duel fuel. I drove the car to the shops this morning and noticed that it was leaking what appears to be coolant from the engine. I had a quick look under the car / bonnet and couldn't really determine where it was coming from. Decided to catch the bus to work and left it there for 9 hours. I came back tonight and started the car and there was a fairly loud clacking / knocking noise coming from the front of the engine. The engine has plenty of oil and the oil light hasn't come on. I checked the coolant the previous weekend before any of this occurred and there was heaps in the radiator / reservoir. The noise went up with the revs. I let it warm up for about 5 minutes and the noise when away. I was about to drive home (about 2 kms) without the oil light coming on / temp gauge rising above half (it's normal operating level). The car appeared to have full power. Any ideas?
  9. #16
    i need to learn Brail.........this shit is just to hard
  10. The Following 2 Users Say Thank You to Avo For This Useful Post:
    Bigcol (3rd June 2016), MB (2nd June 2016)
  11. #17
    472 Post(s)
    My apologies npw112, wasn't very helpful of me at all mate. Was only meaning it didn't sound too good at all :-( Reading your issue thread again (with both eyes open this time) is great to here you've found the mystery clacking noise! Probably should have suggested using a piece of garden hose like an 'ear trumpet' to pinpoint exactly where under the hood your knocking was coming from. Does work quite well, one end in your ear and move the other end around the engine bay touching on suspected areas until bingo found it :-) Cheers and good luck with it, keep us all posted !
  12. #18
    If you can pull these viscous hubs apart on the petrol motor , you can buy oil from Toyota to rebuild it.
    Id also be looking at fitting or getting a shroud made cant be too efficient without one
  13. #19
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    the problem with re-building his one is - the bearing is shot - he would be wasting his time & money re-filling it and re-fitting it
  14. The Following User Says Thank You to Bigcol For This Useful Post:
  15. #20
    462 Post(s)
    Yeah for the amount of time you'd spend pulling it apart. They're cheap enough to just remove and replace.
  16. The Following User Says Thank You to mudski For This Useful Post:
    Bigcol (4th June 2016)
