Results 1 to 10 of 16
Thread: Will GQ Diff centres fit GU. GQ to GU TD42I
    Advanced Mudboss's Avatar
    Nov 2011
    Port Augusta West South Australia
    Hay all
    I'm running 35" on a 03 GU TD42I. The Plaque says iv got 3.9 diff centres. wonna go 4.1 to correct speedo and get a bit more stick. Has any1 done this conversion? Shaft sizes ? Bolt Pattern?
    43 Post(s)
    Will bolt straight in mate..
    4.1 are cheap and dime a dozen.
    4.3 thou will correct 35's to near stock ratio but they are sort after, which in turn fetches more $$$
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    dom14 (1st June 2016)
    Legendary dom14's Avatar
    38 Post(s)
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    460 Post(s)
    Just be careful as utes have different spline sizes. I think its from the utes.
    dom14 (2nd June 2016)
  8. #5
    460 Post(s)
    Yeah i went from 4.3 to 4.1 after the conversion and i sold my 4.3s for more than what i paid for the 4.1s. Around 50bux and you can change the speedo gear so its right too.
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (1st June 2016), dom14 (2nd June 2016)
  10. #6
    38 Post(s)
    How do you change the speedo gear mate?!!! Please tell me how to go about it. Thanx.
    Cheetah Outreach
  11. #7
    38 Post(s)
    I've had no idea same gear ratio and they can be different spline sizes. It's good to know. Thanx mate.
    P.S. Matching the pumpkin code(H233B,etc) doesn't always help?!!
    Cheetah Outreach
  12. #8
    460 Post(s)
    The speedo sensor is located on the left side toward the rear of the gearbox. There will be an electrical lead running to it. A single 12mm, i think its 12mm, hex bolt holds the sensor in. Undo the bolt, remove the sensor, a little oil will come out but not much.
    You then need to see what colour the gear is. This will determin what tooth count it is. Red is 15, yellow is 16, blue is 17 and black is 18tooth.
    If you put larger tyres on, you need to put a smaller tooth gear on as the speedo will read too low. So a smaller gear will increase the rotations in the sensor. The change is about 6% difference between each gear...
    I sell the gears in my store. But if you work out which one you need, let me know and you get a member discount.
    http://stores.ebay.com.au/Northern-4...=p4634.c0.m322
    Edit: Sorry Dom. This is for the GU's only. Can't be done this way with the Q's as the gears are rare as rocking horse poo. I do believe some people mess with the signals sent to the speedo itself with something. It has been documented here...
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (2nd June 2016), dom14 (2nd June 2016)
  14. #9
    38 Post(s)
    Where do you get those gears from?!
    Thanx
    Cheetah Outreach
  15. #10
    460 Post(s)
    Thanx
    For the GQ? I'm yet to find anyone with enough stock. As I would buy 20-30 of each gear. I contacted Nissan Japan, US and the UK, and they wanted a stupid price for what they had left and they are no longer in production. So I left it at that. There is a way to adjust the GQ speedo. Im pretty sure of it. Something to do within the speedo head itself I think.
  16. The Following User Says Thank You to mudski For This Useful Post:
    dom14 (3rd June 2016)
