Sandman82
Hi all, ive tried to find a similar thread, can anyone direct me or have you seen this problem.
I have a problen on a carby 4.2, dual fuel. The car ran fine on both fuels and regularly was swapped between each. A collapsed muffler was causing it to struggle which i eventually replaced after multiple patch ups. Had trouble with idle on petrol after that however plenty of power. On gas it ran fine. Also lagged on take off petrol only.
I rebuilt the carby so the power piston stopped lagging.
Ran perfect on fuel, swapped to gas also perfect. Swapped back to petrol and it wont idle. Still power under load but now backfiring out the exhaust when decellerating and dies under 1000rpm.
Tested the gas valve by shutting off the tank so its not duel fuelling. Fuel pump is fine and new filter. No air leaks.
Had another issue at the same time which was the gas solenoid had cracked and was shorting and blowing a fuse (i think) which is why i checked fir duel fuelling from a leaky solenoid.
What i font understand is why it ran oerfectly for days then after running gas and back to petrol it faults.
Any idea?
