19th May 2016, 05:53 PM
Headlight playing up.
Evening all.
The last few days one if my headlights doesn't want to work unless I give it a firm hit on the glass.
I've tried giving the wiring a jiggle and unplug and take out the globe and it continues to not work.
What else could I look at
Sent from my XT1033
19th May 2016 05:53 PM
19th May 2016, 05:56 PM
my passenger side one does that, comes on, then go over a bump - goes out, another bump, comes back on
checked wiring
checked plugs
nowt wrong with either
changed globe
still does it
I live with it
The Following User Says Thank You to Bigcol For This Useful Post:
19th May 2016, 05:57 PM
Sometimes the element is blown but touches again. Try an new globe or try the other one. Just be careful not to leave a fingerprint on the glass.
19th May 2016, 06:09 PM
Start with a better description of the problem.
What doesn't work? low beam or high beam? is it both sides?, does the high beam warning light in the dash work?, what glass do you hit..... windscreen?
I'm guessing it's a GU we are talking about?
19th May 2016, 06:11 PM
OK. I need to go out soon, so I swap the globes over tomorrow.
Sent from my XT1033
19th May 2016, 06:40 PM
I am he, fear me
... and check the earth and the earth pin in the plug
19th May 2016, 08:02 PM
jay see
Evening all.
Sent from my XT1033
I had a similar problem with mine. Unplug rear and closely examine the socket.
There's a high probability the socket contracts are corroded or dirt preventing the proper contact.
I replaced the plugs. I don't have to bang on the headlight anymore.
http://www.ebay.com.au/itm/H4-HEADLI...sAAOSwT6pV3dib
19th May 2016, 08:04 PM
Bigcol
checked wiring
checked plugs
changed globe
still does it
I live with it
It's an electrical problem. Better fix it straightaway.
19th May 2016, 10:26 PM
dom14
you think so Dom...........?????
been to Auto Electricians several times, and they cannot find the fault
new globes
plugs have been replaced
new up graded wiring harness for head lights installed
new relays
new globes
new fuses
replaced Headlight Wiring Loom upgrade with an even better one
still does it every now and again
not often
maybe once a month for about 20mins.................
19th May 2016, 10:56 PM
the evil twin
Well do.
dom14
Yeah, well do tomorrow.
Funny thing is that the wife came home with a blow headlight and the spot light out the back blow a globe too.
Well that is the 3.
Went out a few times tonight and the lights both where working. Will still swap them over tomorrow
Sent from my XT1033
