11th July 2010, 10:27 PM
What is Winter Diesel Fuel?
I'm doing my first mission in the snow soon and the guy at my local store was mentioning that I need to get winter diesel before heading up there.
What is this and do you need it?
11th July 2010 10:27 PM
11th July 2010, 10:36 PM
SUCH IS LIFE
Otherwise known as Alpine diesel.
Would recommend you fill up with Alpine if you intend to travel to sub 0 deg temperatures overnight. It has additive in diesel to stop it from waxing/freezing up and blocking your filter or pump
________________________
______ 2017 D-Max _______
11th July 2010, 10:38 PM
Administrator
Hi Chris, winter diesel is simply heating oil mixed in with the diesel.
A lot of places already would be using this in cold parts but you can also just get some Chemtech Diesel Power from SuperCheap which will probably be easier.
***Update**** And what Nisspat said, Alpine for sure.
11th July 2010, 10:41 PM
SUCH IS LIFE
NissPat
Would recommend you fill up with Alpine if you intend to travel to sub 0 deg temperatures overnight. It has additive in diesel to stop it from gelling/freezing up and blocking your filter or pump
x2 but you can also by additive for mixing with any pump Diesel that will do exactly the same thing.
Paul
