Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Suspension articulation with marks portal axles
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    I have a 2 inch lift with airbags in my gu. Like others have said, it really doesn't limit your flex. With 5psi in the bag I still hit the bumpstop on full flex, so I would say it doesn't limit flex at all.
    Cheers.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
    Bags will restrict flex a little but bugger all..
    And anyone who blames air bags for chassis damage well imo is wrong..
    You can get +400kg which will tear your chassis apart.. No airbags..
    It is purely overloading the vehicle..
    Airbags don't break it.. the load does..
    If you carrying lots of load or even planning on treating the car rough tower braces would be high on the mods list..
    Sent from my SM-G800Y using Tapatalk
    Dont the airbags give it a place to counter lever the load on.
    too many broken chassis to disclaim it I think
  4. #13
    43 Post(s)
    If chassis were breaking above the airbags then yea.. blame the bags..
    But they all fail at the front spring hanger. .
    So..
    Just my rational thinking.
    Airbags don't cause chassis issues.
    They do hide an overloaded vehicle which then causes chassis failure.. but H/D springs will give the same false sence..
    Nov 2011
    Toowoomba, QLD
    So..
    Yep. I agree that it is the weight that causes the issues, and the reason airbags are blamed is that they bandaid the overloading as it were.
    Also, I'm pretty sure that airbags do cause issues with leaf sprung vehicles (because they apply weight to the chassis where it hasn't been braced) and this has just been transferred to coil sprung vehicles (which merely stiffen the spring as it were)
    My $0.02.
  6. The Following User Says Thank You to Punderhead For This Useful Post:
    BigRAWesty (23rd May 2016)
