Results 11 to 20 of 23
Thread: Provent catch can leaking
    465 Post(s)
    Quote Originally Posted by bazzaboy View Post
    Guys,
    Mine is the same valve except it has a brass barbed fitting. The leak in mine is through the valve, as if it was turned on, but only a steady drip in the off position.
    I think its becasue they use cheap chinee taps. You can get them for around 5 or so dollars. I have the same tap but it has two female threads. And I bought it from Pirtek from memory. Hasn't leaked a drop. I considered a Bunnings irrigation tap but being all plastic and my drain hose runs down and out at the rear section of the front guard and along the chassis rail for ease of draining, I was concerned it may get damage to easy. @Hodge, its just a ball valve. Nothing really special about it....
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Quote Originally Posted by nipagu7 View Post
    i did not get a valve with mine . i just went to bunnings and got a irrigation tap with barbs on it for about $2 . never leaked a drop in 3 years .
    Ive got the same valve and no issues with it been plastic. I used clear tubing and can easily see the amount of oil collecting in it.
  4. #13
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    This all I did works a treat
    Attachment 66793
    Garden hose connector and plastic tap
    out of water bottle
  5. #14
    Jul 2015
    Camden NSW
    6 Post(s)
    OK.
    The replacement tap arrived from the supplier. Looks like the exact same unit. I have taped the threads and put a smear of industrial silicon on the barbs before tightening it all up. I'll be keeping an eye on it to see if this one leaks.
  6. #15
    May 2016
    Provent valve? Didn't know they had one. Up to to run your own hose and drain tap.
  7. #16
    Jul 2015
    Camden NSW
    6 Post(s)
    Quote Originally Posted by LostBenji View Post
    A drain kit ( hose & drain valve/tap ) is an supply option when you purchase a Provent Catch Can.
  8. #17
    May 2016
    Yeah, I seen those cheap-n-nasty kits on ebay. Provent don't make the kits, just sellers "Value Adding" (term used loosely).
    I will use this one for a demo in FAIL: http://www.ebay.com.au/itm/Oil-Drain-Kit-for-Provent-200-/261831447404?hash=item3cf65ed36c:g:waYAAOSwYlJW3NX 8
    • PVC hose, does not work well with oil, goes hard and/brittle. Not good with heat either.
    • Ball valve, these have Teflon seals around the ball. Oil softens Teflon and and leaks will come of it.
    Just my 2 cents.
  9. #18
    Jul 2015
    Camden NSW
    6 Post(s)
    OK ..... bugger!
    Now the replacement valve is leaking. Same issue, slowly leaking through the valve, as though it was open slightly. Time for something new. Maybe I'll try the cheap Bunnings options. Something so simple is starting to annoying the crap out of me.
  10. #19
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    I have had this valve in for about 6 weeks and has not leaked a drip...
    http://www.ebay.com.au/itm/301688208897
    2003 GU SIII Auto Grenade. All the goodies.
  11. The Following User Says Thank You to Softy For This Useful Post:
    bazzaboy (9th June 2016)
  12. #20
    43 Post(s)
    Guys,
    I have the same tap..
    But mine is from a reputable supplier.
    Been on 6 months and no issue yet..
