Results 21 to 30 of 38
Thread: 20+ Psi coasting
    43 Post(s)
    Ok Cat is on its way..
    200cpi stainless cat, 4" body and 3" in and out..
    Ok Cat is not on its way..
    So why tell us if it's not coming?
  4. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    BigRAWesty (2nd June 2016), lhurley (2nd June 2016)
  5. #23
    Unsure on egt as yet to fit gauge..
    Water temp doesn't move from the normal 88-90 though..
    I can't hear the turbo spooling like I can under power.
    Scangauge is reading corrected boost so you may be onto something..
    I'd be fitting some gauges to monitor your EGTs etc before you start all these mods
  6. #24
    43 Post(s)
    Lol. Type. Dunno how but it's on its way..
    Yes should have.. But got to keen. Lol..
    Cats going in and gauges too..
    All on the way..
    Exhaust is done.
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Hey did you end up fitting a Dawes or anything to fix your boosting issues or hoping the cat will fix it?
  8. #26
    43 Post(s)
    Hoping the cat will fix the issue..
    462 Post(s)
    The cat wont fix your issue. I dont see 20 psi as an issue aswell. If it were 10psi i would.
  10. #28
    43 Post(s)
    It's not really an issue no, but it's not wanted.. happy with stock.
    But the cat will assist the lack off back pressure and that has to be only reason why it's over spooling while coasting..
    Not sure if it'll fix it or not.. I'm hoping it does but if not then it'll be valves to take control..
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Bacho86 (3rd June 2016)
  12. #29
    Mar 2011
    14 Post(s)
    All rite, interested to hear how you go.
    Did you ever consider just doing the 2.75" exhaust upgrade?
    People seem to have a lot less issues with this on the CRD, but I think only Beaudesert sell them at around $1200, which is close to double what you pay for a eBay 3" exhaust...
  13. The Following 3 Users Say Thank You to Bacho86 For This Useful Post:
    BigRAWesty (3rd June 2016), Maxhead (3rd June 2016), threedogs (10th August 2016)
  14. #30
    Jan 2015
    Was there an outcome to this As mine (2012 CRD ) does the same boost climbs to 25 PSI
