Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: 20+ Psi coasting
    43 Post(s)
    20+ Psi coasting
    So I have one for the pros..
    I've noticed after the exhaust has gone on when I'm coasting with cruse on or a pedal position just before engine braking comes on, or acceleration boost is running up to 20+ Psi. . Highest I seen was 26!!!!
    When engine braking it's right down at sub 1 psi and under any sorta acceleration it's fine and maxes out at 15 as it should..
    Not sure if it's the turbo over running or a faulty sensor??
    Could it be not enough back pressure??
    Help. I'm now worried about this weekend..
    I've got 2000 road k's ahead of me!!!
    Just drive the damn thing
    43 Post(s)
    Nek minute pin drops....
    Boost wont kill it. What are egts like while this is happening?
    Is your gauge absolute or is it corrected?
    43 Post(s)
    Unsure on egt as yet to fit gauge..
    Water temp doesn't move from the normal 88-90 though..
    I can't hear the turbo spooling like I can under power.
    Scangauge is reading corrected boost so you may be onto something..
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    What's going on here Kallen? You right for the weekend ?
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    blocked egr?
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
    43 Post(s)
    Quote Originally Posted by Chubba View Post
    I bloody hope so!!!
    Quote Originally Posted by trekster View Post
    blocked egr?
    Yes..
    Never thrown a code
    Nov 2012
    Coffs Harbour, NSW
    When I blocked my egr and put 3" exhaust on, without boost control, The ecu couldn't control the boost and if I was just cruising with bugger all foot down the boost would go up to like 25psi+ If I put my foot down there was no problem it would drop back, but couldn't cruise at all.... Might want to check your boost control setup assuming you have a dawes/tilix etc.
    1998 GU RD28T: RIP
  11. #10
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Just clean your MAF and all your issues will magically disappear
    Sounds like a typical 3" exhaust over boost issue, time for dowes valve I reckon.
    ….................... On the move
    ________________________
    ______ 2017 D-Max _______
  12. The Following User Says Thank You to Maxhead For This Useful Post:
    BigRAWesty (12th May 2016)
