Page 1 of 9 123 ... LastLast
Results 1 to 10 of 86
Thread: Territory engine conversion
    Oct 2015
    East Bentleigh
    Hi everyone, I was wondering if anyone else has considered this engine swap.
    A 2.7 V6 Tdi engine from any later model (unfortunately Ford) Territory into a GU patrol.
    I know that its a smaller size than the 2.8 that you can get but I was seriously impressed with the sound, the pull and the economy of this motor ...
    Here are some stats from the ford website:
    Territory MkII TX RWD
    Engine type 2.7L V6 Common Rail Turbo Diesel
    Engine size (cc) 2720
    Compression ratio 17.3 : 1
    Max. power (DIN) 140kW @ 4000rpm
    Max. torque (DIN) 440Nm @ 1900rpm
    No. of valves 24
    Bore and stroke (mm) 81.00mm x 88.00mm
    Injection High pressure common rail
    Engine management Electronic powertrain control module
    While these figures arent mind blowing, I.m sure that a chip and exhaust would make it go even better...
    And they are comparable (better) than the ZD30.
    I was impressed with the sound that the bog standard one at work makes, let alone something worked up a bit...
    Has anyone done this or considered it?
    '05 ST-S with a nice tint and LOTS more to come...
    Big difference in weight though mate..... with the GU being over 400kg heavier than a Territory.
    109 Post(s)
    I have an uncle with a diesel Territory. He pulls a 25 foot caravan all over Australia, albeit blacktop only, but sounds great to me. I've never heard of any issues with this motor and instinct tells me it would be a better alternative to a ZD30. I'm not a mechanic though so this is just gut opinion without technical input. If you could get one on the cheap, and you have mechanical ability, why not give it a crack?
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    I watched an 11 second Territory once at Calder Park. Don't know how drivable that would be in the bush though!
    '96 GQ TD42t
    Quote Originally Posted by Chappy View Post
    That would be a 4.0L turbo though for sure?
    Jul 2014
    11 Post(s)
    Not sure to be honest. I'm not well versed with them. It was impressive to see none the less.
    '96 GQ TD42t
  8. #7
    It would have to be, there are a few patrols around now with the barra engine in them. They are a really good match for the patrol.
    As for the 2.7L diesel though I have got no idea.
  9. #8
    109 Post(s)
    I've got no idea about Territory engines so I don't know if the uncle has 4.0L or 2.7L. Never put my head under his bonnet but sounds nice though! It's a reasonably late model but that's all I know Biskit.
  10. #9
    Aug 2014
    Perth
    10 Post(s)
    why not just go the duramax conversion and be done with it
  11. #10
    it's a modified version of the engine first used in the 2005 landrover discovery 3 (which I know was a slug due to the weight of the Discovery), also used in Jags, BMW X5 and a few others...... built and developed by Ford UK
  12. The Following User Says Thank You to Clunk For This Useful Post:
    MudRunnerTD (13th May 2016)
