Page 84 of 108 FirstFirst ... 3474828384858694 ... LastLast
Results 831 to 840 of 1078
  1. #831
    49 Post(s)
    I slightly remember reading something from @AB on here years ago as Administrator he wasn’t receiving either, IIRC his inboxy thingo was chokers and needed cleaning out maybe?
    Don't know why, but I managed to change my tapper username to jay see. Tried doing it awhile ago and it won't allow it..
    BTW: What was your thoughts Mate on the Pizza in the Dutchy test, any good?
    Have never tried it myself but heard a stick or rock under the lid helps for releasing the steam and assisting crispyness?
    Needs some adjustments. Yes something under the lid would work well, or even having the lid sit to one side (will need to be careful of ash/coals falling in) Also need to reduce the amount of heat from the bottom. Less coals or a couple of logs under the base to prevent it burning.
    Will try again on the next pizza run.
  2. The Following User Says Thank You to jay see For This Useful Post:
    MB (15th May 2021)
    49 Post(s)
    Don't know how, but I managed to change my tapper username to jay see. Tried doing it awhile ago and it won't allow it.
    Once it was out in the open air it did dry up a little, which it needed, taste was same as the others.
  5. The Following User Says Thank You to jay see For This Useful Post:
    MB (15th May 2021)
  6. #833
    Try putting the lid on the coals,put the pizza on that n just put the base over that....easier to get out n works a treat also
  7. The Following 2 Users Say Thank You to Avo For This Useful Post:
    jay see (15th May 2021), MB (15th May 2021)
  8. #834
    49 Post(s)
    Had it in an aluminium pie tray spayed with oil, came out easy, but will keep that in the memory bank..
  9. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Avo (16th May 2021), MB (16th May 2021)
  10. #835
    472 Post(s)
  11. The Following 3 Users Say Thank You to MB For This Useful Post:
    Hodge (16th May 2021), jay see (16th May 2021), Winnie (16th May 2021)
  12. #836
    Mmmmm pork ribs..... Almost as good as beef ribs but a fraction of the cost and so much easier to cook. They are my go to for a quick and cheap cook up every time.
  13. The Following User Says Thank You to Winnie For This Useful Post:
    MB (16th May 2021)
  14. #837
    472 Post(s)
    Away they go early
    For anyone interested, I noticed the new model Coolabah Hark is back at Aldi Healesville for only $199, has a flash glass door too unlike my 10 year old model still going strong
  15. The Following User Says Thank You to MB For This Useful Post:
    TPC (18th May 2021)
  16. #838
    .......... TPC's Avatar
    63 Post(s)
    Away they go early
    Thanks for the heads up Mark, have bought one. Will be hitting you up for recipe ideas now.
  17. The Following 3 Users Say Thank You to TPC For This Useful Post:
    Avo (18th May 2021), MB (18th May 2021), Winnie (18th May 2021)
  18. #839
    472 Post(s)
    Nice work Tony Mate, hopefully you’ll love its simplicity too
    I can highly recommend tack welding on some nails for holding your ribs upright like in post #807 can also stab potatoes, chicken drumsticks on the nails too or lay a full slab of meat atop of the nail tips as well
  19. The Following User Says Thank You to MB For This Useful Post:
    TPC (19th May 2021)
  20. #840
    472 Post(s)
    Lockdown #5 here in Mexico, I’m taking full advantage of the ‘Intimate Partner’ visitation allowance this time around:
    She’s a Dry Aged Old Heifer (860g to be precise) and should keep me company for an hour or two
    Lubed her up and protection on ready for some sexy hot sizzling time later tonight
  21. The Following 2 Users Say Thank You to MB For This Useful Post:
    Rossco (29th May 2021), Winnie (29th May 2021)
