I've put another oil pump into my cr patrol & after putting it back together it would not start. So i've pulled the timing cover off again to make sure the timing was ok. It all lines up with the second mark on the crankshaft pulley(standing in front of the engine & turning it clockwise). The yellow link is in the right place as is the blue links & the cams. The workshop manual does not mention anything about two marks on the pulley.
Is this correct?
Reason: pics
