1st May 2016, 01:09 PM
engine knock
im trying to work out how to link a video i put on you tube so you can hear it but frustratingly i cant and it is pissing me offf
1st May 2016 01:09 PM
1st May 2016, 01:17 PM
Dribble Master
Makka
If you're using a pc,copy the info in the address bar in youtube, then in the quick reply click on the second icon on the right (looks like a film strip) and paste away......... job done
1st May 2016, 01:25 PM
on the Youtube page of your video
underneath is a "add to" "share" "more" little icons
if you click on the "Share" then copy the link that then shows up
all good
https://youtu.be/kMljg4Jy7Eo
1st May 2016, 01:27 PM
for some reason my stupid apple wont tag the line
1st May 2016, 01:33 PM
yay finally did it so here it is what are your thoughts injectors injector pump ?
https://www.youtube.com/watch?v=L2jHqUcsuqA
3rd May 2016, 03:29 PM
Not sure. A diesel guy need to post something to guide you.
16th October 2016, 09:55 PM
well i finally fixed this it seams thats the number 5 position on the pump was gunked up with wax..........
so i tried some snake oil ..........liqui moly diesel purge .......
ran a bottle through sounded a little better put it back on diesel from the tank started knocking again
so i ran another bottle through sounded even better ....... put it back on diesel started knocking again. now each time the knock got less and less .
today i ran another bottle through all was going well then all of a sudden the fluid went like a mud colour.
ran one more bottle through and it just went a little hazy and the knock is nearly inadible
so i recon the number 5 plunger outlet was gunked up with wax im so happy i have near got this sorted ......
will report tomorrow night after my next effort
I never go into the outback with out a decent supply of water,
and the general rule for how much you'll need is three litres
per day , per person, per man per degree over 25 degrees
celcius, per kilometer if walking on foot, in the winter months
dividing it by two, plus... another litre... at the end .... Russell Coight
The Following 2 Users Say Thank You to Makka For This Useful Post:
Sherro (17th October 2016), Touses (17th October 2016)
