30th April 2016, 08:47 PM
Just picked up my very first Patrol
would like to share our new /old Patrol..
2001 GU 4.2 TD
its taken more than a few months looking, and all of the last week to get it home, but finally made it into the drive this arvo... very happy even with the wobble at 85kph and intermittent aricon. webv1.jpg
The Following 7 Users Say Thank You to Dan02 For This Useful Post:
AB (2nd May 2016), Bigcol (1st May 2016), blocko05 (4th May 2016), growler2058 (1st May 2016), katwoman (2nd May 2016), threedogs (18th June 2016), Touses (1st May 2016)
30th April 2016 08:47 PM
30th April 2016, 10:57 PM
congratulations now the expensive bit starts
30th April 2016, 11:01 PM
Congrats.
And so the build begins,
good luck.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
1st May 2016, 09:40 AM
1st May 2016, 01:13 PM
looks nice, now to beef her up
1st May 2016, 01:16 PM
looking good mate
whats your first plan of attack at it.........?
2nd May 2016, 12:13 AM
cheers everyone. I'll be honest didnt realise the suspension wasnt stock until someone suggest it looked a little high. had a look and yep shockies have Raw on them... oh well. anyways big picture is around camping with the kids and lots of it hopefully far and wide. So with that in mind will be building it up to suit. thoughts are around the following
lift - or check existing is good
Body rust protection system
uhf
snorkel
roof cage
suitable safety and recovery gear kit
some basic rear shelving
Basic camping gear ... and we are off.
But before all that will have to sort that high speed wobble, check everything by mech, check whats left on the clutch, 5k service, sus out the intermittent air con issue.
The Following 2 Users Say Thank You to Dan02 For This Useful Post:
katwoman (2nd May 2016), Robo (2nd May 2016)
2nd May 2016, 06:38 AM
Top ride mate. My wobble was fixed with new radius arm and panhard bushes with a wheel alignment.
The Following User Says Thank You to Patasaurus For This Useful Post:
2nd May 2016, 07:43 PM
Dan02
was the car running hot at the time -
at the bottom of the Radiator is a thermal switch, when it activates, it turns the aircon off to help cool the engine
once engine temps lower, it switches off again, and your aircon is running fine...............
2nd May 2016, 07:44 PM
when my old GQ started to have the wobbles, I took the tyres and rims off
got the rims balanced
then the tyres
then re-fitted
no more wobbles
BUT
it could be Anything in the front end causing the wobbles
The Following User Says Thank You to Bigcol For This Useful Post:
