25th April 2016, 05:19 PM
Gu gearbox - ls1 patrol
Hey guys I'm after some opinions please.
I have a 5 speed manual box in my 2000 model gu at the moment which is on its last legs and needs a rebuild. I have converted from the zd30 grenade to an ls1 and would like to know which option would be better long term.
First idea : rebuild my current zd30 box and install the bigger/stronger 5th gear. Was also going to install the marks adapters 5 th gear over drive ratios.... Currently the car sits on 2600-2700 rpm at 100km/hr.
Second idea : remove my zd box and purchase a second hand 4.8 petrol gu box which would already have bigger/stronger 5th gear. I've also been told the 4.8 boxes have a lower 5th gear ratio...... Which would save me buying the marks adapters ratios for the zd box.
Which option do you guys recommend. I am in no way looking at building a race truck, just want a solid reliable gearbox more suited to touring and towing a van.
Cheers guys
25th April 2016 05:19 PM
25th April 2016, 05:21 PM
Id go the 4 speed auto from GMH
T700r
31st May 2016, 01:00 PM
If your good on the tools and don't mind a bit of wiring
6l80e auto, but you'll want 3.9 or 4.11 as a final with 33" tyres
Marks also sell the adaptor for the transfer case
As far a wiring it up that will depend on what computer your running on the ls1
31st May 2016, 03:15 PM
J_o_h_n81
Unless your ls1 is out of a late model vz hsv (which is an L97 i think) you can't run a 6L80/85. It's not just as simple as wiring and ecu, the cam and crank sensors and pickups need to be changed from the 1x and 24x to the 4x and 64x on the motor to communicate to the ls3 Ecu which runs at 1gbps unlike the ls1 which runs at 657mbps for a start then and whole new engine harness/wiring loom would need to be made and list goes on. For the amount if things that need to be changed to make an ls1 work with a 6l80, it's not worth it lol. I'm pretty sure i started a thread about it a couple of years ago and have all the details in there haha
digger12
Cheers guys
To run the tb48 5speed you'll first need an after market tcm and then the adapter kit from marks. The cheapest option is to run a 4L60/65e that are factory mated with the ls1 and get the transfer case adapter from marks. The second and strongest option is to find a 4L80/85e from a holden suburban or a chev suv/truck, first gear is taller and is stronger than the 4l60/65. Some wiring needs to be changed from the 60 harness but also the speedo pickup needs to be moved from memory
The Following User Says Thank You to Alitis007 For This Useful Post:
31st May 2016, 04:47 PM
@alitist007 would Killer Kustom looms have plug and play
harnesses off the shelf???
Also having the taller first gear would that
effect off road gearing in say low 1st ??
31st May 2016, 06:10 PM
SUCH IS LIFE
@TD. I think increasing the length of the loom would shorten the tall gear syndrome whilst giving you much better torque range through the gears. IMO having the right and correct gauge and length of the loom is important......I could be wrong though
________________________
______ 2017 D-Max _______
31st May 2016, 06:47 PM
Atomic tcm from msd
Makes it all plug and play, and they quite ofteren have deal with free harness saving you $150us
So all up under 1k au deliverd, if you have to pay for harness it will put you over 1kAus so you'll have to pay gst
Not hard like it use to be
31st May 2016, 07:30 PM
threedogs
I wouldn't know John, that's a question you'd have to ask them. The question that should be asked is, did whoever spliced the op's loom in the first place leave the plugs for the pcm and tranny in or did they just use what they needed
Nisshead
Makes me wonder if you blow a rod would it be spat or swallowed??
J_o_h_n81
Atomic tcm from msd
There are few different after market TCM's available on the market but the 6L80/85 has one bolted onto the valve body, but saying that you do know that the 6L's use data from the airflow meter to control the shifting pattern, shift firmness and kick down
31st May 2016, 08:18 PM
I can see your not you average key board warrior, you actually know what you are talking about
All the stand alone tcm still use the inbuilt tcm as well, patc also make a good stand alone
31st May 2016, 08:26 PM
Oh alitis is definitely a keyboard warrior. Straight up ninja punk
>>>tappin from tassie
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
